Gearbox - SaabCentral Forums
Old 25-03-05
jappe900 jappe900 is offline
New Member
Default Gearbox
Hello,
Can I use a gearbox of a 900 Turbo 16 (1990) to put in a 900 S (LPT-1993) ? If yes, what work and modifications are needed ?
Many thanks,
Jappe
Old 25-03-05
the Cheese the Cheese is offline
My Saabs: '92 900S, '88 SPG
I'm pretty sure it will bolt right in- no modifications necessary. The only difference between the turbo and non-turbo gearboxes is the final drive gear. This just means that at identical speeds, an engine with the turbo gearbox will run at lower revs than an engine with the non-turbo gearbox.
Old 25-03-05
jefspg jefspg is offline
My Saabs: 88 SPG, 2001 Aero Wagon
I believe the front cover will have to be swapped as the non-turbo uses the old style front motor mount.
Other than that it should bolt right up.
Old 25-03-05
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
The LPT is a turbo, but it would have a solid front motor mount. And type 6 primaries same as a non-turbo.
Go Dutch
Old 25-03-05
gbsaab gbsaab is offline
I put an 93' non-turbo gearbox into my 86' turbo with no mods at all, straight bolt-in. The front motor mount was newer and I kept my old gearbox dipstick, but that was about it, if memory serves me.
900 T16 Tweaked APC
