dire fuel economy & check engine light - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 23rd March 2005
bencf bencf is offline
New Member
My Saabs: 9000CSE2.3 non-turbo
Default dire fuel economy & check engine light
Hi,
I have just aquired a 93/9000CSE 2.3L non-turbo, when. The fuel economy seems dire (15-20mpg at best) and the check engine light is on and sometimes it race's on idle (200rpm upto 1700rpm and back down, etc...)
It didn't do any of this when I tested the car two weeks ago! Any idea what might be the problem (I have a 94/2.0 turbo CSE for spare parts, like sensors)..?
Thanks-in-advance
Old 24th March 2005
tristan_the_trout's Avatar
tristan_the_trout tristan_the_trout is offline
My Saabs: 1991 9000 2.3T Imola Red
hunting idle = vacuum leak?
as for fuel . have no clue i have teh same problem, about 22mpg, after full tuneup; plugs, air/oil/fuel filters. no go..
'91 900 - R.I.P.
'91 9000 2.3L Turbo "Phoenix" - R.I.P. You will be missed
'95 900SE 2.0t Convertible - Flooded during Irene
'91 9000 2.3 Turbo Imola Red
Old 24th March 2005
johncc's Avatar
johncc johncc is offline
My Saabs: '00 9-5 2.3t estate
I would guess it's a Trionic car? If so, try turning the ignition on but not starting the engine. The Check Engine Light (CEL) should flash a fault code at you. You can get a list of flash codes here.
I think the idle problems are symptoms of a rich mixture. Does the car smell rich? It would explain the fuel consumption.
It could be MAP sensor, air intake temp sensor, coolant temp sensor or lambda sensor, among others.
Let us know the flash codes for more advice!
Old 24th March 2005
New Member
There is no mention of Trionic under the bonnet/hood. Just "2.3 direct ignition".
I have followed the instructions to read out a fault code using the CEL - nothing doing, light comes on and then goes off. Ofcourse when the car is started it stays on and the idle oscillates slowly and with decreasing amplitude until it settles.
I also disconnected the battery for a bit to let the ECU clear any 'fault' (suggested by Giles @ Abbott, they happen to be a few miles away), still no joy - Giles suggested it might be the lambda sensor, anybody experience of this fault or changing a lambda sensor?
I have a 'spare' '94 9000 2.0L turbo that I could rob the sensor off - assuming they are the same sensor...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
