8v Valve Shims needed - SaabCentral Forums
Old 01-03-05
MSOEMiller's Avatar
MSOEMiller MSOEMiller is offline
My Saabs: '87 900 8v N/A & '88 900 SPG, Both 5 spd
Default 8v Valve Shims needed
The Saabsite couldn't fill my order for shims, so now I don't know where to look. I'll go to a dealer as a last resort.
This is putting a hold on getting my 8v back on the road, so PLEASE reply if you have some leads . . . .
7 shims
sizes needed in mm
2.36
2.36
2.39
2.34
2.44
2.39
2.41
or as close to those as you can get them.
THANK YOU
Old 01-03-05
pda's Avatar
pda pda is offline
My Saabs: T8, FMIC,173bhp & 228ft lb
eurocarparts Ltd they will have some or Saab dealer they should not be that dear
Paul
_____________________________________
Full Throttle until you see God, then Brake..
Paul
Old 02-03-05
NSE's Avatar
NSE NSE is offline
My Saabs: '83 T8 4dr.
I have a bag of various sizes somewhere but couldn't find them when I looked a couple of weeks ago. I'll have another look tonight.
Joe
My '83 T8 4dr project thread
Old 07-03-05
MSOEMiller's Avatar
The guys at www.eeuroparts.com are searching for me. So, thanks everyone for looking in their parts bin.
FYI. The stocked shim sizes came out to . . .
2.33 mm
2.35
2.39
2.41
2.43
Later
Old 07-03-05
MSOEMiller's Avatar
Good news and Bad news
Good = I have 2 of the sizes ordered.
Bad = Time to call a dealer.
Old 08-03-05
REDTURBO84's Avatar
REDTURBO84 REDTURBO84 is offline
My Saabs: sold
Shame that no one had them laying around.The Saab dealers always treat me like s**t when I tried to buy parts.I'm done with them! I wonder if a motorcycle shop could have the right sizes? They also use shims to set the valves.I once had a Kawasaki KZ750 head redone and they stocked them .Pat
Advice is what we ask for when we already know the answer but wish we didn't.
Old 04-04-05
MSOEMiller's Avatar
Well, this is turning out to be a needle in a hay stack.
My shims from www.eeuroparts.com never arrived. Who knows what happened to them.
The Saab Dealer can't fill my order! The &*#@ wouldn't take an order over the phone and then made me drive there to place the order which can't be filled!
Here's what I need.
2.35 mm Part #7524358, quantity 3
2.39 mm Part #7524390, quantity 2
2.41 mm Part #7524416, quantity 1
2.44 mm Part #722443(6?), quantity 1
My car has been sitting for months! It wants to be driven.
Old 04-04-05
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
7524457 is 2.45mm I believe.
Old 04-04-05
MSOEMiller's Avatar
??? Don't need that size, but thanks for the part number.
Old 05-04-05
nutcase's Avatar
Well they don't list a 2.44 and that's the closest match
Actually, looking at your eeurocarpats list there, the only one Saab list is 2.41mm Something lost in the conversion from imperial?
Old 05-04-05
MSOEMiller's Avatar
Thanks to "Nutcase" I have ordered the shims from www.partsforsaabs.com. It's amazing that I couldn't find these in the U.S.
FYI, the sizes ordered were 2.33, 2.35, 2.39, 2.41, and 2.43.
Old 05-04-05
Si's Avatar
Si Si is offline
My Saabs: Sensonic NG900T, a gagle of rusty c900's
Default Shim?
So I perhaps should add this to 'Questions that are to stupid to ask' but, what's a shim?
Old 05-04-05
nutcase's Avatar
On the 8v engines, to adjust the cam follower clearances you use different thickness shims under the cam follower.
I think as the engine was originally an imperial lump there's been something lost in the translation from inches to millimetres, but I'm glad you got there in the end
Old 05-04-05
MSOEMiller's Avatar
FYI - The "valve shim" is also known as an "adjusting washer" or "adjusting pallet".
Simply, the shim adjusts the valves so that they open and close properly. For example . . . A shim too large on a valve may keep the valve open a bit. A shim too small on a valve will not allow the valve to open enough. Such a little thing can really screw up the engine.
I am installing smaller shims, because the valves were lapped in after I had the head off and skimmed. Lapping is like sanding and makes the valve sit properly when closed. The valve sits a tiny bit higher in the head and the age of the car also means there has been some wear. The smaller shim will make the clearances dead on to spec.
End result should be a car that has good valve clearances for another 150,000 miles.
