Water/Oil in Air intake box - SaabCentral Forums
Old 29-01-05
Ben's Avatar
Ben Ben is offline
My Saabs: Red 5dr C900 16VS
Default Water/Oil in Air intake box
This is a problem with a '86 8V carb 900 with 94k miles on the clock...
A few days ago while doing a standard check of the engine, I found that there was water mixed with oil in the air intake box - quite a bit of it in fact.
It appears to be comming from the rocker cover breater hose which attaches to the air intake box.
When I remove the rocker cover breather hose, and rev the engine, there are what looks like exaust fumes comming out of it - likewise with the oil filler tube.
I`m guessing its the head gasket on the way out? The strange thing is that the water is perfectly clean with no traces of oil in it; and is not under pressure.
Anyone have any ideas what else it could be appart from the head gasket?
Thanks in advance!
Ben
Old 29-01-05
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
do you live in a colder more humid climate? i know somewhere i ahve ehard about condensation getting in there somewhere. Does it smell like coolan't?
headgasket symptoms are : white smoke out of tail, loss of power, water int he oil (can look like mayonaise is int he oil or if really bad oil will look like a chocolate milkshake)-some (tiny bit) mayo in the oil is once again common from what i have heard in the cooler more humid climates! check the coolant resevoir for oil, you can even check the condition of the sparkplugs.
Fun times:
Classic Saab 900 Turbo Convertible, Porsche 911
