Stupid me or stupid shocks...dunno which - SaabCentral Forums
Old 16-01-05
d_ames117 d_ames117 is offline
My Saabs: 92 900T Convertible, 08 9-3 2.0T
Unhappy Shocks
I tried using a nut cracker that I got from Sears but a single nut was too skinny to work. SO I put the other nut back on and gave it a shot. It seemed to work, but now I can't get the cracked nut off. So now I'm going to try and grind it off from underneath...any suggestions?
Thanks!
Dustin
Old 16-01-05
Rhich's Avatar
Rhich Rhich is offline
My Saabs: 1993 Sleeper
Are you taking the shocks off?
Gather this is a shock “issue” from the thread header…
Fronts? Rears?
Old 16-01-05
Sorry...front shocks - I'm trying to replace them with KYB's.
Old 16-01-05
I'm going to buy a grinder tomorrow and was just wandering if anyone had done this? I searched the forums, but the last post was a year and a half ago.
Thanks,
Dustin
Old 16-01-05
Rhich's Avatar
Take a deep 13MM socket and put it over the two upper nuts… then with a long extension you can bend the upper shock shaft until it breaks… just forget using the shock after that…. I believe Matco & Snap-On tools used to make a tool designed just for that purpose….
Old 16-01-05
Vermont Saab Vermont Saab is offline
You can also use a sawsall and cut the shock shaft easily through the lower bushing, (of the upper shock mount) being careful not to cut into the inner wheelwell of the car.
Old 16-01-05
Did you just cut right through the bushing? I just wanna make sure I don't screw this up is all. Was it difficult to get the reciprocating saw in there?
Thanks,
Dustin
Old 17-01-05
Well, I ended up using a 4.5 inch angle grinder with a 5 inch metal cut-through blade. Thanks for the help.
Dustin
Old 17-01-05
john-w's Avatar
john-w john-w is offline
My Saabs: 1989 T8 Special
Cut the bush with a knife, then use a hacksaw to cut through the shocker.
