Front Speaker Grille - SaabCentral Forums
Old 07-01-05
jimmyjabber jimmyjabber is offline
New Member
My Saabs: '91 Saab 900
Default Front Speaker Grille
I just recently purchased a 91 900 hatchback and was planning on replacing the front speakers. I went out and removed the two screws holding the speaker grille down and it seems like there is something else still holding it down. I've tried prying quite a bit, but it doesn't seem to come off. Am I missing something here? Thanks for any help.
Old 07-01-05
pda's Avatar
pda pda is offline
My Saabs: T8, FMIC,173bhp & 228ft lb
once you have removed the 2 torq screws all that holds the speaker grill in are 2 spring clips..
just use a little force it will pop out
p.s. Welcome to Saab Central
Paul
_____________________________________
Full Throttle until you see God, then Brake..
Old 07-01-05
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
There's a couple of small ¬ shaped clips on the underside, which might be catching. From memory, on the UK passenger side (US driver side) there is one on the left hand side of the grille and another at the rear towards the right. Once you've got those 2 screws out it normally just lifts out though - try and angle it in such a way as to avoid the clips catching. I normally use a flat blade screwdriver to lift the edge enough to get purchase on it and then wiggle it out, but be careful as the plastic of the grille is quite fragile.
Edit - OK, I say do it carefully, Paul says force it out. Try both and you can't go wrong
Go Dutch
Old 07-01-05
New Member
Thanks guys, I hate to push plastic parts like that too much, but i gave it a pry with the old flathead screwdriver and it slowly and surely came out. Thanks again.
Old 08-01-05
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
if your dash is old and dried out BE CAREFUL! my car's speakers were replaced by the previous owner and where he pried the grille out it left depressions and small cracks on the top of the dash! depending on your fingers, you can ususally from my experience anyways just flex it a bit and it pops right out!
Fun times:
Classic Saab 900 Turbo Convertible, Porsche 911
Similar Threads
Which do you prefer? echo200 The Lounge 25 08-08-04 02:15 AM
2004 9-3 Convertible 150/7 Stereo Speaker Upgrade Questions remise Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 6 19-07-04 07:55 AM
Front door speaker amplifier- speaker shorted question estrov Saab 9-3 & NG900 Workshop 0 23-06-04 05:18 AM
'91 CD front grille Castor Troy Saab 9000 Workshop 3 11-10-03 10:14 PM
DIY front speaker replacement help Marc Hollingsworth Esq. Classic Saab 900 Workshop 5 31-03-03 08:48 AM
