| Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum |
Hey all,
I am fairly new to this Site, I have owned my 86 9000 turbo for about 7 months and it's been heck trying to get some maintenance done, so I am trying to break open my old tool boxes and give it a whirl with a european car, being as I always used to own cars like oldsmobiles and such. My car was overheating pretty bad recently, until I was able to get the shop next door to work on it and replace the thermostat and the fan switch on the radiator, which cost me more than I was expecting, which is why I am breaking out my tools. I know I sound like a novice, but any idea where the air filter is on this car? I just can't seem to locate it in any obvious places and I know it probably needs replacement very badly. As for some other questions maybe someone can answer me, is my turbo guage on the dash always sits above the green, and when I give it some gas, it moves up a little bit, but very very little. I am wondering if this means the turbo needs adjustment or maybe is it shot all together? I can still hear the whine of the turbo going when the car runs and I can feel a little extra boost, so I am just curious. Any pointers or tips or anything like that? I am not looking for super power, but a little more might be kind of nice, any way, information is always good to have. Talk to you all later.
Hooty! --------- 86 9000 Turbo, working on getting her back in to shape. |
| Sponsored Links | ||
Advertisement | ||
Hi, Hooty. Welcome to the board!
I believe the air filter on the '86, if it was like my '87, is in a square box down by the left-hand headlamp. This will be a flat, square panel-type air filter. Later ones had a cylindrical filter in the wheel-arch and someone might try to sell you one of those as they are the most common type. Don't buy it, naturally. Insist on the flat one. The cover is held on with clips and I always found it awkward on my '87. I think there were a few clips missing by the time I got rid of it. And the reason it's in such an odd place is because it's near the turbo and the air from the filter goes through the turbo first before going anywhere else. Hope you have some metric spanners (sorry, "Wrenches" in American :wink: ) and sockets in that toolbox.
www.saab9000.com - everything you ever wanted to know about the Saab 9000 www.saabits.com - stuff to help keep Saabs on the road |
Doh! Wish I could master tha art of reading a whole message before I write a reply
Anyway, your boost gauge is showing you a problem. Strangely, I just answered about an almost identical problem on another board! It is practically certain that there are some vacuum hoses cracked or broken. This seems much more common in the US than over here in the UK. It must be to do with the climate. Anyway, look for all the thin (5-6mm or 1/4" diameter) rubber hoses around the engine compartment, buy 10 feet of the same stuff from a decent car parts shop (windscreen washer hose will not do the job since once it gets warm it will collapse under vacuum) and replace them all. One goes through the bulkhead (firewall). Replace it too - it's accessible by lifting the plastic cover off just in front of the windscreen, and at least on later cars, goes onto a plastic fitting there. If you're lucky, that will make things a lot better. If not, you might have to do the one that goes from that plastic fitting I mentioned to the boost gauge, and that means lifting the dash top off. Not a huge job, but a bit of a pain. In my experience, though, that piece of hose doesn't suffer so much because it's in the passenger compartment. With the problem you have, you're likely not getting full boost even though the gauge is lying to you anyway. And even with this fixed, there are one or two other things that can cause low boost. When you have the car running properly, I'll bet you'll be surprised at how well it can go.
Thanks Bill,
I appreciate the help and advice. I seem to remember seeing something like that flat box you are talking about, so far as hoses go, I found that one of the hoses was disconnected completely, a little time and effort and I got it back on. And yeah, I have metric tools in my kit, I always seem to need them more than standard so I shouldn't have an problem. I'm going to take a look at all of it this morning now that I can actually see it all in daylight. So far as replacing the hoses go, I am going to be moving soon, so this car is going to need to pull off 1000 miles in a day, which is no problem for me, I'm happy to have power enough to go more than 35 miles an hour up an incline. I did check on the airfilter, and geeze, around here, they run about 28 bucks US, a far cry from the 6-7 dollars of my last car. Oh well, better car, better performance, more expensive parts :P Again, I appreciate the input. BTW, my name is Bill, too.
I knew I should have taken those yoga classes. are there any parts I should be removing before I pull the air filter? I was just out there for about 15 minutes, at least doing a test pull so I can get it done quick when I get the filter, and I got the clips off etc, but still couldn't get the top up far enough for me to even slip the filter out to replace it with a new one. Any additional ideas? I'd appreciate them. Talk to you all later!
Anyway, the Haynes manual says: Quote:
Hope this helps, Bill, Bill.
Sounds complicated, just the way I like it
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
