how do i adjust my clutch on my 900 - SaabCentral Forums
Old 7th November 2004
bwell bwell is offline
My Saabs: Saab 900 98 talladaga
Default how do i adjust my clutch on my 900
put a new cable in a while ago now it has become loose and i have trouble shifting gears .
I cant seem to be able to adjust it??????????????
plz help.
Dead Centre's Avatar
Dead Centre Dead Centre is offline
My Saabs: Red 1994 NG900 se Turbo. 82000 miles
Hi.
The cable is self adjusting?? HAHAHAHA you would not think so?
No really it is a bad design. Best bet is to get you and a mate. Where the cable enters the bulkhead get your mate to pull on the spring and you press the pedal.. This should tighten up the auto adjuster.
Failing that how many miles on the car and what is the history of the clutch.
You may need a new plate kit ect.
Dead
earthworm's Avatar
Saab Sage!
Automatic adjusters are troublesome - in spades.
Better are the old manual adjusters, a very easy job and A man could always tell when the disk or shoe was worn out.
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
You can also do the adjustment alone. The first thing to do is undo the one 10mm nut and the various clips holding the black, trapezoidal relay box to the firewall (if you're in the US. If you're in the UK, well I have no clue :P ). Gently move this box out of the way (there's a big slug of wires coming out of it so you don't want to mess them up). Once this is moved you should be able to see the cable coming out of the firewall. If you grab the thin black part of the sheath and tug and wiggle it while sort of pushing the large rubbery part towards the firewall you'll hopefull hear a couple small clicks. That's it!
Also nearby, you'll see a bracket that holds the cable in place coming up from below. If the cable has slippeed out of this bracket you'll get a squidgy feeling clutch pedal too.
When you're tired of this routine, you can get a manually adjustable cable from thesaabsite and other places. I'm very very happy with mine these days.
Edit: check this post, it's illustrated!
http://www.saabcentral.com/forums/sh...666#post847666
Old 8th November 2004
thanks
I think that should do it
Old 26th April 2008
AddictedToSaab AddictedToSaab is offline
My Saabs: 1995 900 SE Turbo
I have a non adjustable cable. What are my options? Do I have to buy a new cable if I'm showing symptoms like trouble getting into reverse (sometimes) and trouble getting into other gears (sometimes, mostly after I've been driving for a while)?
this bad boy:
Old 26th April 2008
jstrowe jstrowe is offline
My Saabs: 1995 ng900 2.0 'vert, 2000 9-5 2.3T
Generally, the best way to tell if you have a problem with the self-adjusting cable is if there is too much free-play at the top of the pedal and the clutch engages too close to the floor boards.
If you move the pedal by hand, you should only be able to move it about 2cm before you start to feel resistance. If you can move it more than that, the auto-adjuster is not doing its job. That will make the clutch engage too early or not dis-engage fully which causes problems shifting.
John
Old 26th April 2008
I was able to move it more than 2cm. It was more like 2-3" before I felt any real resistance. Should I replace the cable?
Old 26th April 2008
earthworm's Avatar
Saab Sage!
Non-adjustable ??
Thats a new one; there has to be an adjustment; as the clutch wears, necessitating an ever shorter cable...
I fear that the clutch disk is worn out
Better secure a consensus on this one..
The earthworm
'96 900S, Automatic
Old 26th April 2008
Saabohème's Avatar
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
Do what Jmarkert said in conjunction with the following, to avoid damaging the ratcheting mechanism in the self adjuster via the push, pull and tug method. SET the parking brake firmly. After you have exposed the cable at the firewall junction and can see the rubber bushing in the firewall with the spring sheath on the cable, wrap the positive terminal of the battery securely with a rag and tape it on. Standing in front of the bumper and facing the engine bay, look straight down between the battery and the delivery pipe to find the lever where the cable end terminates. Now look for a large bolt head or nut on the transmission housing below the lever. Place a long large pry bar against the nut on the side of the bolt head closest to the firewall and so that the pry bar comes up on the lever arm on the side nearest you. Lean forward on the pry bar to push lever arm back toward the firewall to take the tension off of the cable and with your right hand, gently pull up on the cable where spring is, near the rubber bushing. You will hear several clicks. Remove prybar, get in car and test where the clutch engages. When you have reduced pedal freeplay to approx. 1/2 inch to 3/4 inch, you will be almost done. Replace fuse box before closing the hood!!!. Make sure that the cable locating grommet is still in its bracket and that the cable end is securely and correctly oriented in the lever arm. Now you are done.
To answer the unasked question, the rag on the anode is to prevent an exteremly interesting and unpleasant surprise should the prybar slide sideways to make contact with the anode while the other end is touching the transmission housing or lever arm. I will say I am forever grateful that my large prybar has a large plastic grip handle. If you look at the near side of my battery anode, you can see that sparks were flying when this happens. The black mark is actually a pit about 1/8 of an inch deep. Lucky I did not weld the prybar to the anode.
Old 26th April 2008
Originally Posted by earthworm
Non-adjustable ??
I don't see how it can be adjusted. I located that image I linked that looks exactly like my cable and it's marketed as a non-adjustable.
Old 26th April 2008
Saabohème's Avatar
If that is the Beck Arnley, it is manually adjustable with two open end wrenches where the whit plastic and brass is located. The wrenches push apart the sheath to make the cable tauter.
Old 26th April 2008
hkayssi hkayssi is offline
My Saabs: 1997 900S
Since you're in the UK, I highly recommend you do this
http://www.uksaabs.co.uk/UKS/viewtopic.php?f=2&t=27248
Old 26th April 2008
Oh shi.... Could you be a bit more specific on how this works? Like does it matter on the direction, what am I actually turning? etc.
Old 27th April 2008
Saabohème's Avatar
I don't recall - the last time I had a manually adjustable clutch cable it was on a Lancia Zagato. If it has not been adjusted, you can probably only turn it one way. Try counter clockwise to start, and if you can get a couple of complete rotations, then test the pedal play.
Old 27th April 2008
Okay basically I don't know what to use the wrenches on. Look at the cable. I see two brass (golden brown) nuts on the outside of the middle white plastic. There is a plastic nut on the right hand side (closest to clutch pedal) and a nut that moves around as I turn it in between the white nut and the rounded white plastic in the middle. Order is [Bronze nut] [Useless white plastic] [Free moving metal nut] [White nut] [Bronze nut]
What am I touching? "If it has not been adjusted, you can probably only turn it one way." is ambiguous. I don't want to accidentally break something, if you know what I mean.
Old 29th April 2008
The is a middle (steel?) nut that was moving around freely and on thesaabsite's FAQ it says to just move this around to adjust. Is this correct? If so, I didn't even need a wrench I moved it my fingers.
Old 28th April 2009
davestlouis davestlouis is offline
My Saabs: 96 900s convert
I'm befuddled by this project...All of the nuts are tight...is it the metal one surrounded by plastic? What needs to be loosened and retightened? I must be dense but I just don't get it.
Old 28th April 2009
Its a cable, I would assume it wears down and needs to be tightened. Whats not to understand?
Old 28th April 2009
I just can't figure out which part of the adjuster needs to be turned, and what direction? I've stared at it, tinkered with it, just can't seem to get it. I'm looking for a simple "turn this nut this direction" sort of instruction. My cable looks like the manually adjustable one in a pic several posts ago...can someone just point out which nut needs to be turned? I've done lots of work on SAABs, BMWs and Mercedes over the years and this one just has me stumped. It seems simple enough, I know...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
