dome light - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 27-10-04
Firehead's Avatar
Firehead Firehead is offline
My Saabs: 1989 9000 CD Turbo Automatic;'03 9-5aero
Default dome light
The dome light in my '89 9000 cd is missing the glue or whatever holds it against the rear glass. At certain speeds it begins to make a rattling sound which is annoying. What could i use to fix this? i am not sure what to use.
Old 27-10-04
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: 2005 9⁵ Aero
Garage
Your dome light is attached to the rear glass? Can you post a pic?
If it's something that is clearly broken, try a hot glue gun. That works very well for my small repairs.
Old 28-10-04
benji9k's Avatar
benji9k benji9k is offline
My Saabs: 1992 9000 2.3L Turbo
Are you talking about the third brake light? May be a loose (or missing) screw. Perhaps some rubber washers may help. If not hot glue.
Old 28-10-04
Firehead's Avatar
i dont think there is a screw missing.... There is only a gap between the glass and the 3rd cabin mounted brake light that is only a few millimeters wide so when i drive it started to make vibrating sound while it taps on the glass...hmm hot glue or rubber washer sounds good.. just woundering what did saab use to keep the dome light on the glass?
