| Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum |
I'm starting to get a tick tick from the timing chain [i think]. It only happens on cold starts and goes away by the time the engine is warm. You can't here it unless your outside and sometimes you even have to be specifically on the passenger [U.S] side of the car. If you lift the hood the engine noise will drown it out unless you stick your head right up to the engine the belt side of the engine.
Anyway to keep the timing chain from getting worse? |
| Sponsored Links | ||
Advertisement | ||
You could 1)not drive the car
Update:
I just got back from a 15 min drive. Didn't even hit 3k rpms [it is raining and the streets are slick]. Ticking noise from the passenger side was there after I got to my destination and a rapid ticking was coming from the area approximetly around the valve cover. The noise seemed to be coming from the portion farthest from the front of the car [toward the throttle body an d cabin]. I had my oil changed 2500 miles ago. What can I do to eliminate both? Thanx for the help so far. MUCH appreciated. |
Does this engine have balance chains.
If it does, is there a slight vibration of the engine when idling. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
