Cruise control that just continue to accelerate? :) - SaabCentral Forums
Old 05-10-04
jepper jepper is offline
Default Cruise control that just continue to accelerate? :)
Hello!
I have a SAAB 900i 16v from 1989.
Have problems with my cruise control, it just continue to accelerate when I push the "set"-button. It finally stops (thank god) when i brake or set the crusie control to "off"
Anyone have had this fault?
Thanks. /jepper
Sweden
Old 05-10-04
MSOEMiller's Avatar
MSOEMiller MSOEMiller is offline
My Saabs: '87 900 8v N/A & '88 900 SPG, Both 5 spd
I know exactly what it is. Well, maybe . . .
My mechanic diagnosed this in my '88 SPG during his inspection of the car. I haven't used the cruise control since buying the car, but he tested it.
Apparently, my cruise/turn signal stock is a replacement and a newer style and does not work with the old cruise control relay. The mechanic said he would have to do some rewiring at the relay.
I'm just going to go to the junkyard and get an old stock.
I don't know the wiring requirement, sorry.
Old 05-10-04
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
I don't know the details but it sounds like the vac control valve {is there one of them?} is stuffed. Since the brake stops it, the controller is probably fine. The brake operates a separate vac valve which drops it out at this point. Switching off turns off the vac pump.
OTOH, it could be that it's not getting a proper speed signal but I'd think that would prevent it engaging at all...
Old 05-10-04
Thanks for your answers!
I've open the vacuum pump, seems clean and fine.
Also opened the electronic control unit. Looks like new. No bad soldering.
The pedal switches seems ok.
I was just out testing again. Same problem but I noticed that it will keep the speed as long as I press and HOLD the set-button. Work just fine then.
If I then releases the set button it starts to accelerate and accelerate and accelerate... :
Any more ideas?
Thanks guys!
Old 05-10-04
cjaouich cjaouich is offline
Was that you
http://story.news.yahoo.com/news?tmp...d_nm/driver_dc
Old 05-10-04
Huh, I thougt I had a SAAB
Old 05-10-04
lyricon's Avatar
lyricon lyricon is offline
My Saabs: 92' 900 T16
The system works by running the pump to increase speed then holding the vaccuum with a selonoid valve to maintain the speed. It will do a combination of all this to maintain a set speed. Check the electrical connection to the pump. see that it is clean. It gets the speed sensing from the same signla the speedo uses. If that is funky or the connection there is funky it might not be senseing the speed being reached. The turn sig switch sounds like th most likly suspect though. Swaping out another would solve that question. I went through all this with mine and found the control unit dead.
Good luck
Greg
Old 05-10-04
Groove's Avatar
Groove Groove is offline
My Saabs: '88 900 Aero.
I have exactly the opposite behaviour. Mine works fine if I just press the button once, but if I hold the set button down, it will continue to accelerate. Wish I could offer more advice, but I'm sure it will be something simple.
Old 06-10-04
Good luck
Greg
The electrical connection to the vacuum pump looks like new.
There is also a relay in the vacuum-pump that works like a valve. looks ok.
I´m going to search for a replacement turn sig. switch just to see if it makes any changes.
Old 06-10-04
cdaly's Avatar
Moderator
I think that's correct behaviour. Haven't got the driver's book to hand just now but I seem to remember reading that. Not having CC I can't go and check...
Old 07-10-04
Solved!
I bought a new signal switch today and that stick had the option "TIP" on the cruise control buttons wich it hasn't on the one in the car. It seems like someone before me hav changes the signal switch to an older version or something like that Iäm so glad I didn't burn something Now it works just fine *aaah*
Thanks so very much everyone, especially to MSOEMiller who had the right answer for my problem
