I bought a water pump for my '80 900GL as many of you may already know, but I
decided to get new seals anyway and rebuild my own pump. I decided
to dissassemble the pump I bought just for practice. I followed
instructions at first, supporting the impeller and tapping the shaft with a
drift. It wouldn't budge at all. So I got a gear puller from a
buddy and started cranking on it with a ratchet and all of a sudden
SNAP! The impeller busted! Not a terrible loss because the shaft
gears on the pump I bought were busted anyway, but I am thinking if
that happened what is to say I'll be able to remove my own impeller?
I looked more carefully at the impeller and shaft that broke and it
appears they are welded together?!? Was that the case with some of
them? All I know is if I can't do a better job dissassembling my
own pump I am @#$&ed......
Edit:
I have pounded on the head of the shaft with a hammer with all the force I can muster. To the point where the shaft snapped in half and till the top of the shft is mushroomed and it hasn't budged a millimeter. I KNOW for a fact it's welded on. The question is, why? and who did it? and is there any chance my own pump is welded together?
Edit:
