air conditioning system question - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Cafe > The Lounge
The Lounge For general discussions
Old 17th September 2004
Cojoroh Cojoroh is offline
My Saabs: '04 Saab 9-3 Linear MT
Default air conditioning system question
i'm posting this question in the lounge because i posted this same question in the SS forum a while back but hardly got any responses. i don't know much about air conditioning systems, but it is my understanding that the climate control system uses freon in combination with heat from the heater core to achieve a certain temperature through the vents. my question is, (1.) what settings will use the least amount of gas, (2.) and what settings will use the least freon? i usually leave the temperature at the coldest setting and reduce the fan speed if necessary...but i've seen many people raise the temperature setting to save gas...does this actually save gas, or is it just mixing heat with the cold incoming air? also, i think the new variable displacement compressor used for the new SS may change the equation here. can anyone answer my questions?
Rob in Atlanta's Avatar
Rob in Atlanta Rob in Atlanta is offline
My Saabs: '98 900S/ '06 9-3 Aero
Default Re: air conditioning system question
The most efficient setting is one where the air conditioning compressor does not need to run. When the compressor runs, it produces drag on the engine. The engine must produce more power, thereby using more gas, to operate the car at the same speed. If you only use fresh air, either unheated or heated, then you should be using the most efficient setting on the climate control system.
1. The climate control system in the Sport Sedan (and in the earlier NG 900) uses R-134a refrigerant instead of freon.
2. Regardless of the type of refrigerant used by the air conditioning system, it is not "used" up or consumed by running the system. The refrigerant is in a "closed loop" system and is constantly recycled. The refrigerant acts only as a heat transfer medium. It absorbs heat in one part of the system and releases it in other parts of the system. Essentially think of the air conditioner as a heat pump. It pumps heat from the interior of the car to the exterior. It constantly performs this cycle. The only way that refrigerant, R-134a, Freon or some other refrigerant, is lost is through a leak in the system. N.B. Conventional wisdom instructs us that using your air conditioning system more probably helps to prevent leaks because it keeps the seals well lubricated and tight.
I'm not certain as to how the variable displacement compressor interacts with the need for cooling power, so I can't really address this part of your question. Raising the temperature may in reality only add heat to otherwise already cooled and conditioned air. In that case, raising the temperature might have little or no effect on gas mileage. Maybe someone else knows more about the variable displacement aspect of the compressor and how outlet temperature is regulated.
Rob in Atlanta
'98 900S, 5-Door, Manual, 168K miles
Stefano's Avatar
Stefano Stefano is offline
Saab Mad
My Saabs: 2 9ks,white '87T &'96 Silver Aero 2.0
In fixed-displacement compressors systems, the desired temperature is achieved turning on the system when the air is hotter than the desired temperature range, and turning it off when it's colder (of course the temp range is no large rthan a couple of degrees).So when you say
it can be true if it's to save gas intended as fues, not freon. If the temp is higher, the times the compressor is engaged will be shorter than those in case the temp was lower (I hope I'm clear enough....) so the engine, having to drive the compressor for less time, will burn less fuel eventually. But it's not about Freon consumption, as Rob saied. Freon is only comsumed by leaks.
You saied
The heat from the heater core is not used for that, it's only if you want to heat up the car and defog the windshield that they system turns on the A/C because the cooling that the air receives alloews to moisture to condensate and thus to separate so the air, after being heated, is dry and can successfully defog the glasses. But this combination is only used to defog, as far as I know (I'm sure about my 9000).
Variable displacement systems...... as far as I know, they reduce their displacement when the temp required isn't too cool, so instead of angaging and disengaging all the dime, they just stay engaged all the time but they pump less. This way you avoid mechanical stress, you have a more constant temperature and engine load.
Hope this makes things clear. Please ask if I wasn't clear, I'm not sure I was but I can explain better if you need.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
