Only runnin' the fogs - SaabCentral Forums
Old 19-08-04
ASCsweed ASCsweed is offline
Default Only runnin' the fogs
Is it at all possible to set up the lighting system so that you can run just the parking lights and the fogs WITHOUT the headlights? I know on some cars you can do this, and was wondering if anyone has done this or knew a way to set up a switch so that this trick could be done. Thanks!
-Mike :-??
Old 19-08-04
lukysaab lukysaab is offline
I believe that it is actually illegal to run with just parking lights... Add in just the Fogs won't help. May differ from state to state, yada yada yada...
Old 19-08-04
Dan93T Dan93T is offline
why would you want to do that?
Old 19-08-04
Alex_Saab's Avatar
Alex_Saab Alex_Saab is offline
Pull a fuse?
Old 19-08-04
SQR-900T SQR-900T is offline
thats how they come from the factory in most of europe. Mine are like that. I had my dealer set it like this for me. You need Tech2, ask them to set headlights and foglights to EUROPEAN settings. If the technician knows his stuff he will understand exactly what you are talking about.
Old 19-08-04
20Ted's Avatar
20Ted 20Ted is offline
My Saabs: '03 Audi allroad 2.7T with tip
The laws regarding it are different state to state. Most states require that foglights or driving lights can only be on when the headlights are on, but the city lights on our cars usually suffice as the requirement.
I'm not sure of the exact setup on a 9-3, but on the NG900, there is a fuse that you pull, disabling the daytime running lights, but then you also have to have the system set differently by the Tech II...IIRC, the setting is 'European', which will allow the city lights and tailights to come on (without the full headlights) in the headlight switch middle position, and in this position, the foglights can also be turned on.
Old 19-08-04
STLDWN STLDWN is offline
I have mine set to this setting as well (european setting) and the fogs only come on in the parking light position, and the full headlight position. It does not matter which position the switch is on in order to have just parkinglights and city lights on. However, a word of caution, when placed in the parking light position the parking lights will remain on, when the engine is shut off, you will hear the bell when you open the door. Just be carefull not to kill your battery by accidently leaving the switch vertical in order for you to drive without headlights, but with fogs on.
Old 19-08-04
one1speed one1speed is offline
That's how my passat was set up. Actually, the fog lights are just on their own switch, you had to have the running lights (parking lights) on in order for the fog lights to work. So you could just wire them to their own switch. I used to do that in low light conditions when you didn't yet need the headlights.
Old 20-08-04
cavsaab cavsaab is offline
Originally Posted by STLDWN
Just be careful not to kill your battery by accidently leaving the switch vertical in order for you to drive without headlights, but with fogs on.
Been there, done that ops:
Old 20-08-04
CleveSaab's Avatar
CleveSaab CleveSaab is offline
My Saabs: 98 900SE Coupe, 99 9-3S convertible
Me too, Cavsaab. More than once.
My 1994 900 worked like that. (Parking + fogs).
It is certainly not against the law here.
Old 20-08-04
SAAB900TURBO97 SAAB900TURBO97 is offline
Default FOGS
is the programming thing only a dealer can accomplish this.. ?
Old 20-08-04
CleveSaab's Avatar
Dealer and MOST Saab specialists.
