Water line for turbo - SaabCentral Forums
Old 23-07-04
SPGBOY's Avatar
SPGBOY SPGBOY is offline
My Saabs: '86 900 SPG & '86 900 Notchback
Default Water line for turbo
Im about to replace the lower radiator hose from the pump to the left side of the radiator and as I was looking at it I noticed the coolant line for the turbo was very rusty. What is the proper name for this line, I'm looking for it on eeuroparts.com and I cant find it in the diagrams. Its the one that stems off from the radiator hose and connects to the turbo. What's this thing called?
Old 24-07-04
john-w's Avatar
john-w john-w is offline
My Saabs: 1989 T8 Special
Thats all part of the bottom hose, so it should read something like.. "bottom hose with water cooled turbo"
Old 24-07-04
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
I found that the steel part of this hose was very rusty on the outside - but also about 3mm thick and absolutely fine on the inside. I couldn't separate it from the lower radiator hose though.
Old 24-07-04
SPGBOY's Avatar
Then I guess I will just order the hose and maybe try to clean the turbo line before I put it all back together. Thanks a lot.
Old 24-07-04
ejenner's Avatar
Banned
don't forget to make sure you can seperate the two hoses
