1989 Aero electronic fuel-cutoff - SaabCentral Forums
Old 23rd July 2004
chelo chelo is offline
Default 1989 Aero electronic fuel-cutoff
ProfZ showed me that my 89 has a fuel-cutoff switch controlled by the ECU. So, if I'm tweaking with the APC and about to change my FPR to a 3.0bar one, how do I decrease sensitivity to this cutoff switch? Or does it automatically adapt to the new APC settings?
Thanks!
Chelo
Old 24th July 2004
ProfZ's Avatar
ProfZ ProfZ is offline
My Saabs: 1990 900S 3-door auto. 1988 900S 4-door 5-spd.
The ECU's overpressure safety circuit will kill power to the fuel pump relay if turbo boost becomes excessive. Unless you're planning to run insane levels of boost, this is something you have to worry about only if the wastegate sticks closed.
Because this safety feature has nothing to do with the fuel pressure, changing the FP regulator will not affect it.
Old 26th July 2004
Thanks again.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
