MP Short Shifter Installed + Detailed Install Instructions - SaabCentral Forums
Old 08-07-04
ERP's Avatar
ERP ERP is offline
My Saabs: Turbo X 19T JZW Stg 4, 415hp 532tq
Default MP Short Shifter Installed + Detailed Install Instructions
Initial impressions are very good. It feels a lot better than stock. Also the installation was easier than I thought. I wrote up instructions for it here,
http://www.lehigh.edu/~cak7/Pics/MP/...eSolution.html
I set the adjustable shifter to the shortest amount and removed the reverse lockout. I can easily get into any gear and I still have the 5th gear/reverse bumper.
Eric
Old 08-07-04
Dead Centre's Avatar
Dead Centre Dead Centre is offline
My Saabs: Red 1994 NG900 se Turbo. 82000 miles
Yep mine has arrived this morning. Glory be.
My neighbour will die. He wants one for his WRX.
Dead
As an edit nope it was not the shifter just a deliverey from ebay still waiting
Old 08-07-04
Turbo 900's Avatar
Turbo 900 Turbo 900 is offline
Great write up Eric.
Does it feel a lot tighter and more precise than stock (other than being a shorter throw); or is there anything else you can say about the product?
-Bill
Old 08-07-04
ERP's Avatar
ERP ERP is offline
I think the MP Short Shifter feels great and is more precise than stock. It also fixes some of the other problems of the stock shifter. Take the boot off the stock shifter and push it hard into gear. If you look at the ball joint you can see it flex under force because some of it is made of rubber. This picture shows the stock ball exploded and you can see all that parts. The two rings with the blue * are rubber bushings. When the stock shifter is used these bushings flex and add to the sloppiness of the gear shifter. The other problem with the stock shifter is that plastic bushings at the base (4) wear slowly over time. The bottom of the MP Short Shifter that houses the bushings is slightly smaller than the stock shifter. The plastic bushings fit tighter in the short shifter and it eliminates any excess play from the bushing.
Old 08-07-04
Turbo 900's Avatar
Thanks for the quick reply and detail of what is being improved... I'm debating what to get first:
1- MP Short Shifter
2- MP Steering Brace and Clamp
3- MP Rear Sway Bar
Other than that I am ordering out some new front rotors. Either Slotted and Crossdrilled Brembos or Slotted Rotoras. ERP, I know you have some nice rotors- what's your opinion?
Old 08-07-04
SQR-900T SQR-900T is offline
nice!!! Now thats a product I like. Way to go MP Performance. I like I like!!
Old 08-07-04
BlinD BlinD is offline
wow.. nice product!
Old 09-07-04
Hi I have the ATE Atom grove discs from Parts For Saabs. Had them on over a year now well smart no surface marks run with pads very well no excessive wear or noise under braking.
Take a look ATE
Dead
Old 09-07-04
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
Eric, down on step 5 with using the vise, you spelled know, not knob.
Old 09-07-04
Turbo 900's Avatar
Thanks Dead... those look like some nice rotors and they sell them on TheSaabSite.com which my dad loves.
Old 09-07-04
I want one. But that install looks a little on the difficult side. :-?
Old 09-07-04
ERP's Avatar
ERP ERP is offline
Don’t be intimidated by the long instructions. I wrote it out detailed incase anyone got stuck somewhere. But truthfully most of the dismantling of the consol is straight forward and you can do it without any instructions. I was worried at first about removing the shift knob and the old stick, but it turned out to be real easy.
I’m using the Zimmerman Crossdrilled Rotors with the stock pads and I’m real pleased with the stopping power. The crossdrilled rotors do a much better job at expelling heat. With stock rotors I would experience shuttering and slight brake fade during a 120-60 mph quick slow down. With the crossdrillled rotors I can go from 120-0 mph with no fade or pulsating. Stock pads produce a fair amount of dust but it cleans off easily. Crossdrilled rotors might go through pads quicker but their cost is low and I like the increased stopping power.
Old 09-07-04
I think im gonna break down and do it anyway. If I need help I got smart friends lol. ERP: Do you suppose you could take a pic of your car in first, then in second? I wanna see how much the throw is shortened w/o the reverse lockout.
Old 09-07-04
sethsev7n's Avatar
sethsev7n sethsev7n is offline
My Saabs: 2001 9-5 Aero 5-spd!
does anyone know if we can still get them for the 136$ sale price?
Old 10-07-04
What he said..?? :wink:
Old 12-07-04
Yeess it has arrived haha.
Thats a nice bit of kit. The wife looked at it and shoock her head.
So just got to fit the shower and then the shifter.
I was wondering wether to remove the reverse lift. I would like to fit a custom knob and shift boot.
Will this affect reverse lock?
Dead
Old 13-07-04
bkrell's Avatar
bkrell bkrell is offline
My Saabs: gone: '01 9-5 2.3t, 1997 900 SE turbo
If you remove the entire knob assembly with the black tube that fits down the length of the shifter. But can't you seperate that from the knob itself? I think Munki has a topic on this over on his site.
Old 13-07-04
Yes BK I have had a scan at the Munki's site and the knob removal guide.
So what are we saying the knob has nothing to do with reverse lockout? Is the spring just to do with the lift?
As I read Munki's words the spring is just the reverse coller and the actual reverse lockout is at the base of the shifter. So if I remove or rather just don't use anything but the actual base of the shifter when I rebuild it with the MP kit. I will have no reverse lock catch at the base of the shift stick. It appears that the part of the mechanisam is actually integral to the outer plastic sheath of the original shifter.
Hmm I rather like the reverse lockout its a Saab thing
Dead
Old 13-07-04
bkrell's Avatar
Yeah, but there's bound to be a way to seperate the sleave from the knob.
Old 14-07-04
So if I install this. How do I remove the reverse lockout with it? And how do u know how low u can take it?
