SAAB Owners Club (UK)
Home Saab Pictures Saab Classifieds Saab Dealer Listings Saab Forum
Go Back   SaabCentral Forums > Saab 9-3 & NG900 > Saab 9-3 & NG900 Workshop
Old 14-06-04, 04:02 PM
needboost needboost is offline
Default 65 mph + acceleration = steering wheel shake
Hey guys,
I have experienced quite a bit of steering wheel shake... At first, I thought this was due to the alignment being off, or perhaps due to one of the wheel being mis-balanced. First, I realized, cruising along however, that I did not notice any pull - I believe a bad alignment would pull the car towards 1 way or the other.
Then I noticed something else. The steering wheel vibrates only when I accelerate at 65+ mph. If I am at 70 mph, but cruising without my foot on the gas, ie on a downhill on the highway - I notice no shaking of the steering wheel. If there was a tire or two that was not balanced, wouldn't I feel it even when cruising?
Any ideas anyone?
thanks
Old 14-06-04, 04:10 PM
boxman's Avatar
boxman boxman is offline
My Saabs: 9-3 SS Aero + 9-3 SV Aero
drive shaft inner c/v joint,this is common and is caused by the cup being worn
boxman
Old 14-06-04, 05:18 PM
Thanks.
Hopefully this is something still covered under warranty....
thanks again.
Old 14-06-04, 05:29 PM
Oh, 1 thing. The car only has about 45k miles on it... should that have worn out already? wth?
Old 14-06-04, 06:39 PM
NelsenW NelsenW is offline
I had the same problem with my '99 9-3 at about 48k miles. As boxman said, it was the tripod bearing. Somehow, the grease escaped...the bearing wears ridges in the companion cup. Before you get into changing that out though, I would try to elminate any potential tire related possibilities (alignment, balance, pressure etc).
Old 14-06-04, 06:54 PM
boxman's Avatar
the other thing to think about is buckled rims depending on your wheels some styles are more vunerable than others
boxman
Old 14-06-04, 08:31 PM
Thanks.
No rim problems, not that I could see. Keep in mind, my front 2 are pretty new, about 5 months old, and my rear two are about 1 year old. Come to think of it, I believe I had them balanced when they were rotated around 5 months ago.
Hope this is under warranty. If so, maybe they can take a quick look at it, and figure it out.
thanks again.
Old 15-06-04, 04:45 PM
sunnydude sunnydude is offline
I am having the same vibrations on my 97 900. It isn't the wheels as just replaced them. Previous owner had three bent wheels. If it is the CV shaft, how much to fix? Can it be done by yourself? How to verify?
Old 15-06-04, 09:38 PM
SPATL's Avatar
SPATL SPATL is offline
Boxman hit my first guess as well. I had to replace an inner driver from the cup having a crazy wear pattern on it. The wierd thing was that it hadn't lost its grease but still wore the grooves in the cup.
It is a pretty involved job but not impossible.
The only other thing the check is sometimes is that regular tire balancing does not get rid of some vibration. The Hunter GSP9700 Wheel Balancing machine is a high speed balancer that has remedied many vibration problems that were undetected by other wheel balancers. Lucky for me the place I get my tires has such a machine.
You can go to their website and then search for a local shop that has such balancer. Might be worth you money to have that checked. I know a few 17" rim owners that spent lots of money having things replaced when it eneded up being solved by the Hunter GPS9700.
Hunter GSP9700
Old 16-06-04, 12:31 PM
True, but we got our saab with extended warranty - so I'm going to first see if Saab wants to fix the problem for me .
I hope its not dangerous as it will prob take me a couple of weeks before I can get out of work to take the car to the dealer.
copyright © 2003 saabcentral.com, All rights reserved - website by WDD serviceshttp://www.whiter.co.uk - valid xhtml - valid css
SaabCentral is an independently run website and is not affiliated in any way to Saab Automobile AB
