Tramsmission has delay , Heater, Radio not working??? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 06-06-04
saabjeep saabjeep is offline
New Member
Default Tramsmission has delay , Heater, Radio not working???
I just recently purchased a 1989 Saab 9000s. The car runs great but I am having some probloms with the transmission, reverse takes awhile to engage. If I go from drive to reverse and reve up the car it engages after almost a minute, there is no noise associated with it.... it does it smoothly. Also my blower for my heat and AC is not working along with the radio everything has power but nothing is working. I would apreciate any help or info....thanks
Old 07-06-04
benji9k's Avatar
benji9k benji9k is offline
My Saabs: 1992 9000 2.3L Turbo
Check the transmission mounts, someone on another thread mentioned how if the mount is sagging, then it's harder for gears to engage, especially true of reverse. Also the level of fluid, it may just need a top-off. If those checks don't pan out, maybe someone else more transmission knowledgable can give help.
Do you have ACC? If so, try running a fault check on it. I think you hit Auto and vent at the same time, it's two of the corner buttons... The display will say zero as it runs checks, and if a number comes up, that's how many fault you have. May have to replace to blower motor entirely, as they do wear out. If you don't have ACC, see if the fan works on high only. It may just be the resistor that's gone bad on it. A cheaper and easier job.
As far as the radio, my first suggestion would be to disconnect the ground from the battery for 20 secs, and reset the radio. You have the code for it, right?
I'm out of preliminary ideas. Anyone else, did I miss something?
