centrifugal advance distributor? - SaabCentral Forums
Old 17th May 2004
c-saab c-saab is offline
Default centrifugal advance distributor?
Anyone know if someone makes them for Saab engines? Back when I was bringing my '73 Karmann Ghia back to life, I made the switch from vacuum advance to an aftermarket centrifugal and a host of problems (and later maintenence needs) disappeared. I'd like to do the same with my '86 8V 900, as some of those familiar timing symptoms are appearing. But I find no mention of these things existing in the Saab universe. Anyone know?
--Colin
Old 17th May 2004
Willy Wonka's Avatar
Willy Wonka Willy Wonka is offline
My Saabs: 5 Red C900T16 Verts
Default Re: centrifugal advance distributor?
--Colin
Which ones? Leaky diaphram? bad vac line? stuck advance pivot? Out of time?
Old 18th May 2004
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Don't the 8v distributors already have counter-weights for centrifugal advance? I know the 16v distributors don't have an advance function, apart from that delivered by the retard capsule under very high manifold depressions (but I don't know how much advance this provides).
Wouldn't you expect distributors on non-turbo cars to have an advance function? :-?
Old 18th May 2004
It tends to drift "out of time" again after adjustments, and though I've replaced the hose, and so shouldn't need to again, it's eventually going to be time for a full replacement, and when I do, I was hoping to replace with a more robust part, as the centrifugal advance ones are (at least the ones made for VW).
The 8V does come with an advance-- it's a vacuum advance with a metal biscuit-looking thing (diaphragm?) on the dist. body and a vacuum hose to the cylinder head (as I recall). As engine speed increases, vacuum in the cylinder increases, sucking the diaphragm, pivoting the advance mechanism in the dist. It's always struck me as ingenious but rather Rube Goldberg. Are there weights in there also, Matthew? I've never noticed.
So no one's heard of such a distributor design (cent. adv.) for Saabs?
-Colin
Old 19th May 2004
ProfZ's Avatar
ProfZ ProfZ is offline
My Saabs: 1990 900S 3-door auto. 1988 900S 4-door 5-spd.
Car manufacturers went away from pure mechanical (centrifugal) advance because of emissions concerns. And many vacuum-advance capsules (which used to supplement the mechanical spark advance) became vacuum-retardation units, to pull timing down from 10 degrees advance to zero at idle!
You might try an aftermarket company like Accel or Mallory to see if they make purely mechanical dizzies for the SAAB. Alternatively, ask your local speed shop where you can get your own dizzy "recurved" (meaning, have the springs that restrain the flyweights recalibrated for optimum performance). This requires a dyno, and is usually not cheap. But, hey, look into it if you like, and let us know what you find
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
