| Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900 |
I finally invested in a calibrated boost gauge (and new vac piping) A lot more involved than I imagined...These old SAAB's are put together too well!
So... What is the typical stock boost settings for a 92 T16S Base boost and Max boost ? cheers.... saves me trawling the forum. (I did provide a pic though! |
| Sponsored Links | ||
Advertisement | ||
Garry
You could have done with buying the other 'TIM' gauge which is calibrated from -1 to +1.5 Bar. It will show more swing, and the one you've got is typically for cars boosting over 1.4 Bar. But hey it works, just wont move much :wink: Peak boost on a T16S with standard (black) APC wih factory settings still intact on the pots and running 95RON should be 0.75Bar. If not see if optimax makes a difference. Most cars will run something like 0.65-0.8 depending on how well the system is working and the condition of engine componenets such as air filter, fuel filter, plugs, leads etc! |
Just got it because it was cheap :P and I need to do some basic actuator setting up.
More detail would have been nicer up to 1.5 bar but hey ho Looks like im boosting up to 1 bar with a modded apc with conservative pot settings. What should base boost be? As I have a 9K Fmic and a 3" exhaust system on order base boost will probably need redoing. I was going to calibrate the wastegate to just above stock. |
As Ross stated Maximum boost pressure on your car is .75+-0.05. Basic boost is 0.35+-0.03.
Thanks chaps.
Looks like im aiming between the 0.5 notch and the notch before it on my bar guage. |
Garry
Same guage as mine. My one boosts at a maximum to the end of the yellow, though mostly to the 1 bar limit. (though I have had the APC tweaked). Do not think Tim guages are the most sensitive and the needle on mine 'vibrates' at idle, but accurate enough I think. Brian |
Brian :idea
If you fit a piece of capillary into the system (down by the Tpiece for example), this will hold flow better and settle out any fluctuation. Makes readings more positive and less eratic. Ross :! |
My gauge seems to oscillate very quickly rather than vibrate at idle. certainly not distracting. If anything the oscillation seems to indicate an improved sensitivity// that it is possibly picking up the slow spin of the compressor?
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
