9-5 vibration on idle - SaabCentral Forums
Old 24th July 2013
xLordJeevesx xLordJeevesx is offline
My Saabs: 2000 Saab 9-5 Linear Wagon
Default 9-5 vibration on idle
Hey, guys. Been on this website too much since I have been slowly bringing my 2000 Saab 9-5 wagon back to good health.
I have been unfortunately having a lot of problems with my Saab recently. It is on its 137k mile mark and showing lots of signs of an old car. The main problem I am having with my saab is the engine vibration.
There is a nasty vibration when sitting at idle. It goes through the steering wheel and makes your teeth rattle. Though, once you get going and gain some rpms, the rattle is gone and it drives like any other car. Is this a motor mount issue? It seems that once I get going though, the rattle would intensify.
Any help would be appreciated.
Old 24th July 2013
saabtwin saabtwin is offline
My Saabs: 9-5 estate & saloon & NG900 vert
Almost certainly the mounts, three of them and not cheap. If you want to check, the easiest one to get to is under the "U" shape engine bracket above the serp belt. Remove the bracket and then try to move the bolt in the centre of the mount. If should be very very stiff, mine could be moved with a little finger.
Old 24th July 2013
riccster riccster is offline
My Saabs: pair of 2000 9-5's one a wagon, one not
Sounds like you need new mounts. There's four of them: one behind the engine, one under the battery, one under the front, and one on top under the big U-shaped bracket. Like saabtwin says, start with the one under the big U-shaped bracket. It'll cost about $100. I recently changed that one out on my 9-5 wagon and boy did it make a big difference.
Old 24th July 2013
I will start by replacing the mount above the serpentine belt and see if that does the trick. I replaced the belt yesterday. The bolt moves around in the socket without any force. I am definitely gonna get on that.
Thanks for the speedy replies guys!
Old 24th July 2013
Rarelibra's Avatar
Rarelibra Rarelibra is offline
My Saabs: 2004 9⁵ Aero "Griffin" Maptun̾
Garage
the ones called "vibration damper"
http://www.jimellissaabparts.com/sho...hString=damper
Old 24th July 2013
bahrm4 bahrm4 is offline
My Saabs: 2002 & 2003 Saab 9-5 Linear Wagons
Default maybe a fix...
I replaced all 4 mounts, one at a time. Torqued to spec. Vibration is better but NOT gone. Maybe I missed a step? The right side was definitely shot. I suspect something on the timing chain side...not sure if anyone can help me good luck!
Old 25th July 2013
zoli.m13's Avatar
zoli.m13 zoli.m13 is offline
My Saabs: MY98 9-5 B205E SE M/T
Garage
Just a thought: all spark plugs are OK?
Old 25th July 2013
I'm going tomorrow to pick up some new ones. I thought this too. I'm not sure the last time they have been replaced since I have bought it. I also am not sure its the recommended NGKs.
Can't hurt to try for some pocket change.
Old 25th July 2013
zoli.m13's Avatar
Garage
I use only NGK BCPR7ES-11.
9-5 2 lpt 4 cyl man B205E, stage 0
Old 25th July 2013
griffinpower griffinpower is offline
My Saabs: MY06 9-5 Aero
In addition check for vacuum leaks.....they will cause tons of vibrations in the motor.
I did not notice is the car Auto or stick? and does it happen in idle and in gear or just in gear?
Old 25th July 2013
It is an auto. It happens just when the engine is idling. Regardless of gear.
I'm picking up just BCPR6ES-11's down the street from my gym. For a set of BCPR7ES-11's, I would have to drive about 30 minutes.
I will look into checking for vacuum leaks.
I will update once the new plugs are in tomorrow. It would be awesome if those do the trick.
Old 25th July 2013
So when I buy the 7's I usually buy online and order 2 sets at a time.
This is one of the sellers I use.
http://www.ebay.com/itm/4-NGK-Standa...85fe16&vxp=mtr
Old 25th July 2013
JohnLear JohnLear is offline
My Saabs: 9-5 99 build low blow turbo
I was also going to suggest plugs as one possible maybe. You may want to be careful about changing the heat range of the plug, which is what you'll be doing with the alternative plug you say you'll be using.
If you don't know, the first numeral in the NGK plug identification code denotes the heat range of the plug, with a lower number being a 'hotter' plug and higher being 'colder'. If you use a '6' instead of a '7' then the plug will tend to run hotter and this will increase the chance of pre-ignition (from a glowing spark plug tip) under heavy load.
This isn't to say that you will get pre-ignition, but the chance at least increases, and my understanding is that supercharged engines tend to be more prone to pre-ignition problems than are naturally aspirated engines.
Please preface the following paragraphs with 'it's my understanding that";
If pre-ignition does occur, then I'm fairly sure this would be detected as a 'knock' and the ignition would retard, but since in this case the (pre)ignition event is occurring at the plug before the plug actually fires, retardation of the spark may not help.
I put "at the plug" in italics because spark retardation would tend to help reduce / eliminate knocking if the pre-ignition were spontaneously originating from another point in the combustion chamber and thus creating two flame fronts (one originating at the source of pre-ignition and the other from the correctly timed plug firing). In this case the two rapidly expanding flame fronts will collide and cause a possibly severe 'knock' against the rising piston. In this case retarding the spark will retard the point at which the two flame fronts collide, when the piston is higher in the cylinder, lessening the severity of or even eliminating the knock.
But, with a single flame front originating too early (possibly much too early) from an overheated plug (too 'hot' a plug), the flame front will prematurely collide with the rising piston, and cause knock, so in this case retarding the spark (which in this case isn't the source of the single ignition event, as it fires after the horse has bolted) will not retard the point at which the flame front collides with the piston crown, and knocking won't be reduced.
Uncontrolled knock is a bad thing, and not always kept in check by the knock sensor. Knock sensors can only really help with minor knocking events, such as you might get with the wrong grade of fuel (which tends to create pre-ignition originating from some point other than the spark plug, i.e. tends to create two flame fronts, so more amenable to spark retardation).
Some manufacturers recommend more than one heat range plug (for use in different conditions), but it doesn't seem that Saab lists the '6' plug as an alternative to the '7' (at least not in the handbook), so I'd be careful about using it. About the only time you might want to risk a hotter than standard plug would be in an engine that tends to foul the plugs, such as one that burns a fair bit of oil (the hotter plug tip will tend to stay cleaner because the heat helps burn off deposits, helping prevent misfiring).
Regards,
John.
Old 25th July 2013
The BCPR6ES-11's are the ones that came stock from the factory for a stock tune 2.3t. I feel I should be alright.
Old 25th July 2013
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
Regards,
John.
6 is the right temp range for a stock tune, colder plugs often foul on these cars if they are run stop/start or not up to temp...
Old 25th July 2013
Installed the new plugs. Engine definitely starts way better and gives me more confidence. You would get a very rough start sometimes. The spark plugs in there were some cheap autolite plugs. Pretty old and worn.
Unfortunately, still vibrates. But, I have figured out that if you put pressure on that U-bracket mount in a turn with some simple g-force, you can definitely hear and feel it.
New mount is coming in on Saturday.
Old 26th July 2013
My handbook specifies the '7' (no mention of the '6'), possibly for Australian market cars assuming a hotter climate? At any rate, one range either side of the 'stock' plug is unlikely to cause a major problem, I was just urging a degree of caution.
Regards,
John.
Old 26th July 2013
In that case, might the DIC be suspect, considering all I read about it being so prone to damage caused by wrong / worn plugs?
Yet there is still some poor ("rough") starting? Has the idle problem completely disappeared? You had poor idle before, tends to suggest any "g-force" related symptom might be a separate issue since there won't be any g-force happening at start up or idle...??
Regards,
John.
Old 26th July 2013
Let us know how it goes with the new mount.
I can tell you I have run every plug known to man and data logged most of them in my old OG9-3 making 300HP and found a slim margin of difference in the plugs during normal operation.
The only real difference i saw was that non NGK's tended to wear out a little quicker.
Old 29th July 2013
Got the new mount on! Works great! Engine light is off now. Runs smooth as butter!
Even a person like me who has had very little time holding a ratchet had no trouble at all doing it. Simple prop up the engine with a jack and block of wood, take off that funky U-bracket, unbolt the old mount and then just reassemble.
Thanks guys for your help. I luckily got a new mount for free from a family friend.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
9-3 2.0T turbo engaged at idle, increased idle RPM's and vibration palong 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 14 9th July 2015 10:44 AM
Vibration at idle turbo1992 C900 Workshop 1 1st May 2011 10:22 AM
Idle Vibration Rubicon_Joey 9-5 Workshop 5 7th July 2010 09:43 PM
Vibration at idle shoestring saab 9-5 Workshop 7 16th November 2009 06:24 PM
Vibration during idle jwwells 9-5 Workshop 9 2nd April 2009 02:09 AM
