ABS / Wheel Speed Sensor? - SaabCentral Forums
Old 4th May 2004
swdmus's Avatar
swdmus swdmus is offline
My Saabs: 1991 900s and a 1994 900SE Turbo
Default ABS / Wheel Speed Sensor?
So I hear he ABS and the wheel speed sensor are the same thing. Im guessing that only one of the ABS sensors is also the wheel speed sensor? and Im also guessing that the wheel speed sensor is on the front of the car not the back because when the tires spin in the winter the speedometer goes up? now if im all right here Im wondering if the speed sensor is on the right or left wheel?
Can someone help me find the correct abs sensor for the wheel speed?
Old 4th May 2004
bkrell's Avatar
bkrell bkrell is offline
My Saabs: gone: '01 9-5 2.3t, 1997 900 SE turbo
The info I have just give the procedure as:
Ensure fuses No. 17 and 18 are okay. Raise and support
vehicle. Turn ignition on. Rotate wheels by hand. ABS control module
should send a pulsed A/C speed signal to terminal No. 7 (Gray/Green
wire) of main instrument display No. 1, and terminal No. 5
(Orange/White wire) of main instrument display No. 2. If pulsed signal
is not present, check for an open or short.
Of course, this will require you to pull the cable to the instrument panel!
It also mentioned speed sensors on the input and output safts of the transmission. Obviously, though, your problem is tied to ABS. The sensors are pretty simple devices. You should visibly be able to tell if something is wrong with them.
Old 4th May 2004
bkrell's Avatar
Oooops! Forgot this part!!!
ABS ECM receives wheel speed information from left front
wheel sensor at terminal No. 7, and is grounded at terminal No. 6.
Information from right front wheel sensor is received at terminal No.
5, and is grounded at terminal No. 3.
Left rear wheel sensor information is sent to ABS ECM
terminal No. 9, and is grounded at terminal No. 8. Right rear wheel
sensor information is sent to ABS ECM terminal No. 2, and is grounded
at terminal No. 1.
Now, anything else????
Old 4th May 2004
boxman boxman is offline
My Saabs: -
i think that the speedo gets its speed signal from the abs ecu not a wheel sensor but this is an asumption 'cus unless both front wheels are moving the speedo doesn't work
boxman
Old 4th May 2004
bkrell's Avatar
Right, but the ABS ECU gets it from the ABS/aka speed sensor. That info I posted is excerpted from the manual.
Edited due to stupidity.
Old 4th May 2004
bkrell's Avatar
Try this. That right view of the sensor is actually supposed to be showing it on the backside of the rotor.
Old 4th May 2004
swdmus's Avatar
Thanks guys that problems fixed I started the car up to day and the speedo worked fine I guess that sensor or something dryed out.
Old 4th May 2004
bkrell's Avatar
After all my hard work!!!!!!
Didn't I say something about rain????
Old 4th May 2004
swdmus's Avatar
Damn Rain I hope that all
Old 8th March 2009
Saab Max's Avatar
Saab Max Saab Max is offline
My Saabs: SAAB 900SE V6 2.5L / 9³SE 2.0/03 9-5Areo
at terminal No. 1.
Im now confuse i thought it speed sensor came from the back left wheel.......? (2000 9-3) or am i wrong.......?
Old 8th March 2009
earthworm's Avatar
Saab Sage!
The speed(RPMs) is taken from all four wheels; only the left rear is used for the speedometer.
The earthworm
'96 900S, Automatic
Old 11th March 2009
Saab Max's Avatar
How do i tell if the ABS computer / pump........... is bad or sensors........ not sure what to do i have ABS light on also check engine
Old 11th March 2009
earthworm's Avatar
Saab Sage!
Codes ?....I do not know
Do check the electrical connectors at the ABS.
If you jam on the brakes, do you feel any pulses at the pedal ?
The earthworm
'96 900S, Automatic
Old 11th March 2009
Darren900's Avatar
Darren900 Darren900 is offline
My Saabs: None
The only certain way is with a tech2 reading the codes. If the car is post-1996, the CEL can be diagnosed with a generic reader.
Old 11th March 2009
Saab Max's Avatar
No pulses after the ABS light came on ( CEL and brake warning light also on)
on for about a week now
Old 11th March 2009
Saab Max's Avatar
Car is 2000 9-3.......
Old 8th December 2014
gbutcher gbutcher is offline
My Saabs: '03 9-3 Arc, polar white with chromes
I have a 2003 9-3 sedan and I recently just had my front suspension replaced and after the car came back from the garage the ABS/traction control/stability control message all came up on the SID. I removed both from tires and checked the wiring. There was no evident damage. So i disconnected the sensors and took a resistance meaurement of each sensor. One reads as a short circuit and the other as an open circuit. Which one is the faulty sensor?
BobSaabit's Avatar
BobSaabit BobSaabit is offline
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9³ 'vert
You need the 9~3 SS forum... we don't cover your model here. The only 2003 here is the convertible, which is the old generation.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
