| The Lounge For Saab related posts of a non-technical nature |
I recently posted this thread with more details, but I wanted to ask those of you in here what you think?
Is it reasonable that a 2001 Saab should have a wheel ripped off (hub,cvjoint and all) in a 25mph impact with an average height inclined curb? I'm trying to figure out if I have any recourse to go to Saab waranty and claim that the car must have been defective for such a minor curb impact to cause this kind of damage. I mean, I have hit curbs way harder with other cars I have owned over the years without even knocking off my alignment. What do you people think? |
| Sponsored Links | ||
Advertisement | ||
Well I am taking a class in engineering dynamics right now. I can tell you that hitting something the wrong way like a curb, even one at low speeds can put hundreds of thousands of pounds of force on parts like wheel hubs for a split second. If you hit it and the forces were somehow transferred to a part of the car that was not designed for a high amount of force... SNAP! As for this being covered my warranty, dream on... unless you can tell them "I was just driving along and the wheel fell off" that could work, but they will probably inspect it and find that there is curb damage / broken suspension parts... Also, you seem to be will versed in hitting curbs :-? you should probably try to avoid those. All in all, this sounds like the normal result from hitting a curb. Now, granted, the NG-900 does have a rather flimsy front suspension. it's not going to take to hitting a curb like a V-8 RWD American car is… something like that will drive right over one, get no damage in the process, keep on going and not even loose it's alignment out of it.
However, BOTH tow truck drivers that arrived on the scene seemed puzzled how that amount of damage couls be inflicted by a curb impact. Well. My inmsurance will cover it either way, but I'd rather not pay my deductible and raise my premiums if I can show that some weakness or error in the car caused the damage to be of this extent. Thanks for your input. |
Make a comprehensive insurance claim, and stop driving over stuff dude.
From the only respnse I have had thus far it seems as if my first assumption (that if a wheel comes off that easily, something must be wrong) may have been wrong. |
Well you could always TRY to see if they will cover it under warranty... I don't think they will go for it, but who knows. otherwise, go the insurance route.
curbs...gotta hate them...my c900 had an 'encounter' with one, came out with the wheel on, but not good, lots of suspension damage :-?
It didn't even knock the Celica out of alignment, and I was going about 40 when I hit the curb. |
See.. this has been my experience with curbs in the past. They may pop your tire or mess up your alignment, and if you have really bad luck even bend your rim... The whole thing about the car being torn apart by it really sketches me out though... |
Well - hit a curb at about 40mph in my Mitsubishi Galant and not much happened - car jolted a bit...
There was a bit of alloy missing as well... Wheel didn't fall off though. Also did the same in my Fiesta Zetec S - (I've only learnt to drive recently - so been a bit mad up to this point) More alloy gone than on the Mitsubishi and this was at a slower speed. Also am quite practiced at loosing the rear end and slamming into curbs. I've been through three rear sub fames on the Fords I've had. Never had my suspension collapse as Mattlach describes. Don't think it'll be sorted under warranty either.. :-? |
I thought that modern european regulation cars where supposed to withstand a 30mph collision with a standard hight curb (however high that is) without permanat damage (might miss-align the steering).
I've tried looking on the web but can't find any references. I would talk to saab, doesn't sound right to me. |
Unfortunately, yes it is reasonable to loose the wheel et al. The city of Atlanta has been busy adding new curbs to the islands between traffic directions (the 2-3 foot wide section between north and south bound) just after many of our intersections. Unfortunately some brilliant SOB decided to add 4” tall square cut curbs rather than rounded curbs thus ensuring substantial damage to any unfortunate car that hits one. This alone is not that bad except that in many of these intersections the lanes shift 1/2 lane over as you drive though the intersection. Thus if you are in the inside lane and drive strait to the other side of the intersection you will wreck your car. Good thinking huh?
Depending on the circumstances, I sympathize with victims of curb impacts. |
Sorry to hear of the mess. Tiverton has a stretch of road where they are using 1" metal plates to cover trenches. I dread that, and have to drive at least 4 times a day.
Sounds like your chasis is probably bent too. If there was enough force to tear out/off stuff and it was fastened properly, then there probably was enough force to cause the front rail on the frame to bend. There are shops that use lasers to align the frame. Claim it to the insurance, and get a complete comprehensive analysis/estimate. Good luck. |
heres the breakdown... ![]() A. Travelling roughly 40mph. Spot a group of unusually attractive members of the fairer sex at W. Slow down and appreciate the view. (mistake #1 I need to work on my gawking tendencies B. Travelling at approx. 25 - 30 mph. Looking up and suddenly remembering where I am. Hit breaks + turn wheel. C. Stopped halfway up in the grass, with damage mentioned above. After that walkthrough, its probably safe to say the wheel hit the curb at least slightly from the side, which probably better explains the damage, but I am still not convinced that something like this should take a wheel off... |
Excellent diagram!
I suspect it's the angle of attack that is the cause of the problems, if you had hit it straight, it would probably be 2 bent rims and not much else, but I guess you would have been going faster How high was the curb? (sorry if I missed....) |
It depends on whether it was the wheel or the tyre that caught the curb. Catching the metal will transfer large loads into the suspension components in directions that they were not designed to take.
Some modern cars do seem to have sacrificial suspension mounting systems to try and prevent damage to the chassis. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
