Faults/Codes with Engine Controller Upgrades? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 25-04-04
rando67 rando67 is offline
Location: NJ, USA - '03 2.0T Vector SS, BSR Stage 1, Aux-IN
Default Faults/Codes with Engine Controller Upgrades?
I would like to start a post here with folks that have either a BSR or Hirsch upgrade to indicate if they have had any codes set and/or SID indications occur.
I might be wrong but I believe I have read that some folks have seen a tracking control (Electronic Stability Control) SID warning with the BSR upgrade. Is this true? Others?
This is not to get paranoia but rather what could be expected in having a upgrade applied to a vehicle.
Old 25-04-04
Saba's Avatar
Saba Saba is offline
Default Re: Faults/Codes with Engine Controller Upgrades?
The stability control warning only comes on when the PPC upgrade is being uploaded. It doesn't come on after that.
Old 02-05-04
SS's Avatar
SS SS is offline
Here is the weird part though. I was told that its normal for the traction control and stability control to flip while tuning or un-tuning, BUT i noticed something weird. The last time i tuned, the stability control and the traction both failed. Two days ago i had to take the car in, so i un-tuned and ONLY the traction control failed. Why didnt the stability control fail too?
I dont like it how something decides to fail whenever it wishes to !!!
Good one rando, i hope everyone chips in this one!
Old 02-05-04
Saba's Avatar
Well they're not really "failing". Only the warning signals aare being tripped. I would expect tuning in the BSR setting may produce different responses to tuning the stock settings back in. Maybe not though.
Old 02-05-04
Sol Sol is offline
Default Faults / codes
I have my ECU updated from Hirsch. Ones with step one and twise with step 2. I got first edition step 2 and last edition step 2. No problems what so ever.No wrongs signals or problems with TSC or something else.
The car feels like a more than 3,0 L suction engine. Powerfull and smooth on the same time.
Old 02-05-04
Paul's Avatar
Paul Paul is offline
Vendor
My Saabs: -
As Saba states nothing is failing. The reprogramming of the ECU causes the various sensors on the car to throw temporary error messages because they are not receiving the signals they are expecting and that is it, there is absolutely nothing to be concerned about.
It is just the nature of doing the upgrade with the ECU in situ and while the ignition is turned on.....
Old 02-05-04
Saba's Avatar
Default Re: Faults / codes
I would say even the Hirsch upgrade would trip signals whilst loading, but you don't see that because of the nature of the upgrade. I have NO problems with my PPC. It works better than I expected.
Old 03-05-04
aeroild aeroild is offline
I don't remember seeing any failure warnings when Hirsch upgraded my car. They used a laptop plugged into the OBD-II diagnostic port.
Old 03-05-04
Saba's Avatar
Ok I stand corrected ops:
Old 03-05-04
Sol Sol is offline
Saba,
What you mean better than expected ?
Old 03-05-04
Saba's Avatar
Saba,
Well I expected not to get the full 29 hp, 45 Nm gain as quoted by BSR. My dyno results confirmed that I got exactly that (at the wheels). I was expecting that gain at the crank. The turbo rush is much more pronounced than expected. Pull in 4th gear is outstanding, didn't expect that. Extremely happy with what I got.
Old 05-05-04
mav238 mav238 is offline
I am really tempted to get the PPC loaded in my 9-3, but given these "hiccups" in the ESP warning light, just worried that eventually something more permanent may happen to the engine. Yes, I know, the extra 30 hp and 30 lb/ft torque is tempting... but... just wish BSR will work out these bugs...
Old 05-05-04
Paul's Avatar
Vendor
My Saabs: -
these are not bugs.
It is perfectly normal behaviour, as the ECU is being upgraded the various onboard sensors are being confused and throwing errors. As soon as the upgrade is complete all is back to normal. How many times does this need explaining :-??
Old 05-05-04
SS's Avatar
SS SS is offline
Well then howcome the person on this forum who witnessed Hirsch upgrading his ECU didnt see any "throwing" of codes around? On top of all that, i see it reasonable for someone to be worried over and over again as the fact of the ECU flipping is not that normal! The FACT that the ECU is giving these notices means that something is not normal. First time i installed the PPC, i did not recieve any faults. I uninstalled it and again, no faults. Then when i re-installed it, i recieved stability and traction faliure, and when i un-installed, only traction failure. I dont see this as normal! What? The ECU gives failure notices whenever the **** it feels like? I dont think thats normal!
EDIT: If there is an explanation of WHY the ECU sometimes gives failure notcies and other times it doesnt, then yes, maybe its normal!
Old 05-05-04
When I started this thread I was just inquiring about 'codes' when in execution and not when uploading/downloading. And right now I can't say for sure if there are or aren't 'codes' after the PPC has been loaded (actual running in the car with PPC). As in a response as "yes, I have experienced 'codes' during operation with the BSR/Hirsch."
Just as a related question ... say I revert to the last software that was in the vehicle previous to the PPC, go to the dealer, and they upload a new version of software. Then reload the PPC software. Will the PPC store the newer software that the dealership provided? Just curious? Maybe this is a question for BSR.
Old 05-05-04
Paul's Avatar
Vendor
My Saabs: -
Well then howcome the person on this forum who witnessed Hirsch upgrading his ECU didnt see any "throwing" of codes around? On top of all that, i see it reasonable for someone to be worried over and over again as the fact of the ECU flipping is not that normal! The FACT that the ECU is giving these notices means that something is not normal. First time i installed the PPC, i did not recieve any faults. I uninstalled it and again, no faults. Then when i re-installed it, i recieved stability and traction faliure, and when i un-installed, only traction failure. I dont see this as normal! What? The ECU gives failure notices whenever the *** it feels like? I dont think thats normal!
I have twice in this thread stated what I have been told personally by BSR, the explanation seems perfectly logical and reasonable to me.
You should remember that 1) You are not getting any failures only warning messages, nothing has actually failed. 2) These error messages only appear during upload of the software 3) Everything is fine once the upload is complete.
If you are still not happy with the explanation then perhaps you should take this up with BSR.
Old 05-05-04
Cool - that is what I wanted to hear. I just thought there were some folks that had it otherwise.
Old 05-05-04
SS's Avatar
SS SS is offline
Not about being not happy with it, but more like not the explanation i was looking for. Perhaps you misunderstood what explanation i was looking for! Anyways, its alright! No problem!
Old 05-05-04
Saba's Avatar
Error codes I have observed.
Uploading BSR settings
"Traction Control Failure " lasts for about 2 seconds
"Stability Control Failure " chimes and lasts for about 3 seconds.
"Traction Control Failure " lasts until end of update. Clears itself automatically.
Uploading Stock settings
"Stability Control Failure " lasts for about 2 seconds
"Traction Control Failure " chimes and lasts for about 3 seconds.
"Stability Control Failure " lasts until end of update. Clears itself automatically.
Driving
None, I have driven over 5000 km with it installed.
I have done this a few times now and the messages have been repeated. Its not random, they occur in sequence and are obviuosly a response to the upload process.
Hirsh probably doesn't have the messages because they obviously have the T8 algorithm and are able to adjust settings that avoid the trips.
BSR had to crack the T8 setting.
Its no big deal. Jeez I reckon more warning messages appear on the SID caused by bugs in Saab designs than in the BSR design.
Old 05-05-04
SS's Avatar
SS SS is offline
Saba, do they clear by themselves or you have to clear them. Cause when these things happen to me, i have to turn off the car, take out the key for everything to re-set and then its gone!
