19 mpg - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 05-04-04
tracker tracker is offline
Default 19 mpg
Is this about right for my 86 9000 Turbo cos i dont think it is. Do anybody have and remidies or reasons for this low milage.
Old 05-04-04
9000anni 9000anni is offline
No way is that correct.
It is difficult to say what could cause this, It could any number of things.
Do yu have any unusual symptoms ? Difficult starting, misfire issues or anything similar to help diagnose the fault, as it could be anything from mechanical wear to a faulty component, to being just needing a good servicing.
Old 05-04-04
greenphotos's Avatar
greenphotos greenphotos is offline
Location: Flying in my Vector in Basing-St'oke - 2002 9-5 Vector
Mine is difficult to start sometimes and backfires occasionally when starting, and i get CR*P mpg any ideas?
Mark
Old 05-04-04
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: 2005 9⁵ Aero
Garage
19 Highway?
Old 05-04-04
kemosaabey kemosaabey is offline
My Saabs: MB 190E ex 9000i 900i 900GLi T16Sx2 99x3
if thats US gallons, quite possible with city driving/heavy right foot...
Also if you're going by the EDU, they're not always that accurate..
Old 05-04-04
UK gallons and thats suburban driving. Nothing seems to be the matter starts fine and no back fireing. Apoart from a petrol smell when its ticking over. What mpg am i suppose to be getting
Old 05-04-04
djtaylor djtaylor is offline
My Saabs: 9000 Aero
Fuel leak?
Old 05-04-04
chico_85's Avatar
chico_85 chico_85 is offline
My Saabs: 02 9-5 Aero
Dirty air filter?
Old 06-04-04
As far as the MPG goes, you could in theory only get 19 MPG if it's being booted, I would imagine that given you can smell fuel then there is a leak somewhere than needs investigation, but it would have to be dramatic to account for the fuel loss if it's only giving 19MPG.
Has the car been serviced recently ? as this could be the reason for the low MPG.
I would start by checking for air leaks from hoses and around the inlet manifold, and take a look at the spark plugs to see what kind of condition they are in, you can tell a lot from these.
http://www.ngksparkplugs.com/techinf...q/faqread2.asp
But there are so many factors that can cause this, such as mechanical wear, valve timing, clogged air filter or a faulty sensor, it may be worth having a tuning specialist analize it on a rolling road.
My old 9000 turbo (84 model) gave about 26-28 Mpg, but I didn't drive it hard, on a motorway run, it delivered about 32 mpg.
Hope this helps. let us know what you find !
As for Marks backfiring, this can be down to valves, either wrong valve timing or needing regrinding, or air leaks in the system or really bad ignition timing. A compression check should help discover if it is a valve issue and try a visual check of vacuum pipes and listen for air leaks is all i can suggest.
Old 06-04-04
Whats the best way for cheaking for air leaks. I dnont think theres a fuel leak cos there aint any stains on the floor.
Old 06-04-04
Hi,
Usually if you listen for a hissing sound at the pipes leading from the inlet manifold. Do a visual check for obvious signs of cracking etc.
You should be able to follow most of the pipes to their location, if possible, remove a tube and block off one end and try to suck on the tube to see if it can hold a vacuum.
Hope this helps.
Dave
Old 06-04-04
My Saabs: 9000 Aero
Further to the checking for air leaks, try using a piece of washer tubing or similar as a simple stethascope.
David.
Old 06-04-04
microcat36's Avatar
microcat36 microcat36 is offline
My Saabs: Four Saab V6's and a 2.3 FTP
If you are prone to leaving your car to idle when frosty or at any other time this can knock your mpg for six, found this out after i went for a run and got 33mpg couple of mornings frost, leaving the car to warm up instead of getting the scraper out and bingo 22mpg. try watching the mpg tumble when not in gear.
