1989 9000cde ACC Problem / sunroof - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 19-06-02
zahidk zahidk is offline
New Member
i have just purchased a saab 9000 cde turbo automatic... but have some niggles...
to keep it simple... it the acc unit isn't working anymore.. no fan at any speed...
any ideas other than a replacement unit.
also sunroof only opens in vent mode and not fully... any ideas..???
Old 25-07-02
TomTurbo TomTurbo is offline
New Member
Re. sunroof
It might be the contacts on the switch.
These instructions should help.
http://saabnet.com/tsn/bb/9000/index.html?bID=113297
This afternoon the sunroof on my 3 day old '91 9KCD stopped closing. I manually cranked it closed, hit the switch and it would open again, but not close. I cleaned the contacts and all was fine.
I found a 1-1/2" putty knife to be a good way to loosen the seam between the console and the switchbox. It also helps release the interior latches of the switch box. In both cases I was working the putty knife parallel to the sides of the switchbox.
Old 26-07-02
Chris Nye Chris Nye is offline
New Member
Hello mate,I might be able to help, I had the same prob myself, I've only had mine about 3 week's and i got it off an old dear who didn't know how to use it!! anyway all that was wrong with mine was where it hadn't been used for a long time the motor had seised, so I took some of the bolts out on the plastic cover, drivers side lifted the corner and hit the fan casing with a hammer :smile honest it works sound now try it before u buy a new fan, hope that help.
