Small Problem With My First Car - SaabCentral Forums
Old 4th March 2013
chevroletc20 chevroletc20 is offline
New Member
My Saabs: 1997 Saab 900s
Default Small Problem With My First Car
Hello everyone,
I saved up my money all summer and just purchased my first car, which I love; a 1997 900s. The car has the n/a 2.3 with the five speed manual. My 900 has just a bit over 119000 miles and runs quite well. My only problem is that the defroster won't blow air correctly. Whenever I need the defroster; very little, if any air comes from the vents. The heat works fine and all other vents are fully functional besides the ones on the dash. This is creating quite a vision problem for me. I'm pretty handy and was wondering if anyone had any ideas on how to fix this problem.
Thanks so much!!
Old 4th March 2013
Pontius DIO Pontius DIO is offline
My Saabs: .
Do you have manual heater controls? Sounds like it's not diverting the air properly. If it's a manual climate control with knob sliders, one of the cables might of come loose, not sure if possible on these, but maybe something fell into a vent (kid jamming pencil in a vent and falls through duct blocking air door diverter) maybe one of the diverter doors is broken?
Electronic climate control is vacuum controlled I believe.
Old 4th March 2013
New Member
Ok, yes my car has manual controls. Sounds like the next step would be to take off the dash and get a look inside of the vents?
Old 4th March 2013
davidlyx's Avatar
davidlyx davidlyx is offline
My Saabs: 93 SE convertible 2001
With manual control, I suspect it's something inside, not the knob problem, as for the air distribution knob, there're no cables, but direct control of the knob to the inside valve. I think it's the problem with the inside valve, which is fixable when taken out. However, not a small job to take the valve out.
Old 5th March 2013
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
Originally Posted by chevroletc20 View Post
Hello everyone,
Thanks so much!!
Does the airflow vary at all when you turn the distribution knob? Do you feel any resistance or hear something moving when you turn the knob (with the engine off so it's silent)?
My guess is that either the diverter is seized somewhere in the vent/floor position, or the "toilet roll holder" that connects the knob to the diverter control has broken. Of course the former could lead to the latter. The tests above could tell us what's going on.
I believe that some people have basically forced the diverter to floor/defrost position for the winter. However it's better to fix this.
If you are ambitious, you could pull the passenger-side console cover. (Be careful, there are tabs you can break.) The toilet roll holder will be easily visible. You should be able to figure out if it's the knob/holder or somewhere down in the diverter.
Old 5th March 2013
crispin9-3 crispin9-3 is offline
My Saabs: 97 Talladega, 99 Vert, 08 Vert
Garage
While trying to fix it would be better - I gave up.
I tried the screw method, silicone spray, yelling at it, fake tears with begging - nothing worked.
I ended up putting it on the floor / defrost for the winter and I will change it back to the dash vents when warmer weather comes around.
To manually change it pull the glove box and the side panel. The white 'toilet paper roll' is right there, rotate it with your hand. Put panels back in, takes around 10 mins 2x per year.
Old 5th March 2013
EdT EdT is offline
So it turns, but very very stiffly?
You might need real tears from a fake clown or something.
Old 5th March 2013
New Member
haha, thanks for the advice guys. I guess I'll just pop off the panel and rotate "the toilet paper roll". My fan speed does change just fine with no resistance, the problem is solely that the defroster won't emit air. Thanks again!!
Old 5th March 2013
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
Just an FYI it uses stepping motors that receive a PWM signal from the ACC unit.
Old 5th March 2013
New Member
My car does not have auto climate control
Old 5th March 2013
jakejm79's Avatar
Saabista
I know, it was just an FYI for people that stumble across this thread and have ACC so they aren't misinformed.
Old 6th March 2013
treekiller treekiller is offline
My Saabs: 1997 Saab 900 SE convertible
The toilet roll paper holder can be part of the problem though, the manual control knobs tend to lose teeth and stop working. To dig yourself out of a hole you can pull off the hot/cold to use on the directional setting or, vice versa.
Tags
defroster
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
small problem av_dumitrascu NG900 & OG9-3 Performance, Mods & Tuning 2 3rd November 2009 01:49 PM
small problem Cathal 9-5 Workshop 7 4th October 2009 01:11 PM
Hi all, Small problem. Mechanicalrepairs NG900 & OG9-3 Workshop 4 1st April 2009 09:26 AM
A small car accident with a big problem chumster The Lounge 5 17th August 2007 04:59 PM
Small problem or paranoia? Xedus129 9-5 Workshop 1 16th February 2006 09:48 PM
