Rear Differential Gasket Source in UK? - SaabCentral Forums
Old 8th January 2013
grimslade grimslade is offline
My Saabs: 1994 900T Vert
Default Rear Differential Gasket Source in UK?
So, next on my list is draining and replacing the gearbox lube (sorry, Jim M!--call me superstitious...). Mine is a 92 900T, with no drain plug, and i have no idea whether the lube has ever been changed, so I'm thinking to go through the rear differential cover and clean out the screen while i'm in there. But I need a replacement gasket, and can't find a source for one online. Anybody have any leads?
Thanks,
grim.
N.E. Swede N.E. Swede is offline
My Saabs: 4 c900, 97 9k Aero, 02 9-5 aero
I've got about a dozen that I bought at an estate sale, don't mind posting one to you if you can't find any closer
Thanks, NE Swede! I'll let you know if I have any luck closer to home.
Meantime, if I empty the gearbox from the differential cover, how much gearbox oil should I expect to need to refill?
jdwertz's Avatar
jdwertz jdwertz is offline
My Saabs: T5 c900
I believe it somewhere in the ballpark of 3.1 Quarts ~ 3 Liters
Thanks. I realize that is the specified volume of the gearbox, but I've seen numbers around this site as high at 6 quarts/liters, and I didn't know whether I'd get more out from the back than I would from a drain plug, if I had one. My last 900 was an 87, and had a square plug.
S900t8v's Avatar
S900t8v S900t8v is offline
My Saabs: Trionic 5.5 1984 900t 8v
Garage
The maincase is 2.7 litres and the primary case 0.3 litres total = 3 litres
You won't drain much out of the primary case unless you park it on a hill with nose up and leave it for a decent while. If you do this you then need to prime the primary case by adding 300ml in through the breather port at the top of the case.
Thanks again!
Old 9th January 2013
anjum anjum is offline
My Saabs: C900 vert white 92, c900 vert 92 yellow
Try Neobrothers or failing that Dave at Warwick Saab Centre in New Southgate. Thats where I got mine from. But you may find you don't need it, buy some Loctite 518 from ebay.
Also ask him about the original Saab thermostat.
No love on neobrothers (though they do have the OEM thermostats listed...). Perhaps I'll ring up Warwick. Thanks for the tip.
peva's Avatar
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
You'll probably find the gasket comes off in one piece and is reusable. It's fairly thick and durable. As extra insurance use some loctite 518 on it. It's always worked for me.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Warped Head, Thicker head gasket source needed SaabGuy30 9-5 Workshop 6 2nd September 2012 10:02 PM
Rear Differential Questiom chasmanz28 9-7X Workshop 5 14th February 2012 09:20 PM
For Sale: rear differential McCarthy69 Parts for Sale/Wanted - North America 0 3rd May 2011 09:41 PM
differential gasket 88saab900s C900 Workshop 16 5th August 2010 03:46 AM
Differential cover gasket replacement? Vollblut C900 Workshop 19 8th July 2010 07:06 AM
