900 Turbo AC Pulley diagram - SaabCentral Forums
Old 29th December 2012
wagerton wagerton is offline
New Member
My Saabs: 900 Turbo
Default 900 Turbo AC Pulley diagram
I bought a well used 1987 900 Turbo, the AC belt is missing and I think there is supposed to be an idler or tensioner pulley. There is not, I suspect that it mounts on a bracket that has a stud sticking out on the starboard side of the engine. I suspect the old pulley seized and the prior owner removed it and the belt.
I need a picture of the tensioner pulley set up or a diagram in order to ensure I get it all put back correctly.
Anyone know the correct replacement pulley part number, OEM or aftermarket.
Banman's Avatar
Banman Banman is offline
My Saabs: 91 900s turbo/ezk (sold) 97 9000 CSE
Mines off at the moment. I'll take a pic for you tomorrow and post it if noone else chimes in sooner. The pulley/bearing are available at your FLAPS. The bracket and hardware you'd need to grab at a junkyard if you're missing.
Banman
'91 16vT
'97 9000 CSE
'75 IH Scout
Old 30th December 2012
scantar's Avatar
scantar scantar is offline
My Saabs: 92 900t vert, 98 9000
The idler pulley just spins freely on the shaft at the back (front) of the engine. I doubt that it seized up...more likely the p.o. just removed it to take the ac out of the belt equation. I have an extra - with the mounting bolt - that you can have since I pulled my ac from the vert.
So what you're saying is that I need to find a way to make my rod longer?
1992 900 Turbo convertible, 1998 9000 CSE
New Member
My Saabs: 900 Turbo
The bracket and stud (w bolt) are there, just the pulley is missing, i see they are available on ebay for 16$, I'll just order one and see if it fits, any idea what length belt goes on that set up?
The system has about 1 psi in it, I think I'll vacuum the system out and see how long it hold vacuum before putting 50$ worth of R12 in it. Plus its 38 degrees outside right now, so the urgency to fix it is not high.
scantar's Avatar
Section: HC50
Top Width (in): .5
Top Width (mm): 13
Outside Circumference (in): 47.125
Outside Circumference (mm): 1196
You can just walk into your local McParts store and ask for the ac belt for your car. It'll show in their computer and they most likely will have it in stock.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
95 900 non-turbo diagram? tjr12090 NG900 & OG9-3 Workshop 1 21st February 2012 03:26 PM
Pulley diagram or pics? Kevster C900 Workshop 12 22nd October 2011 11:55 PM
Help with Saab Pulley Diagram Mr. Lahey NG900 & OG9-3 Workshop 7 11th August 2011 02:19 PM
Turbo Diagram shadys210 NG900 & OG9-3 Workshop 8 27th June 2009 11:56 AM
Need the Pulley Diagram 1987 T16 Turbo elementforlife C900 Workshop 4 19th August 2004 11:33 PM
