Coolant going low FAST only in winter, fog on windshield - SaabCentral Forums
Old 19th November 2012
mattzat mattzat is offline
Default Coolant going low FAST only in winter, fog on windshield
Thought, with as many data points, we could narrow down my problem.
I have a coolant issue. In the summer it may go down very slowly or not at all, but come winter I go through jugs after jugs of coolant.
It's a 2000 9-5 SE, V6
Here are the facts:
1. If the heater is turned on before the car warms up, the windshield gets foggy. If I wait a while, the window doesn't fog up.
2. There is no coolant leaking onto the interior floor.
3. Sometimes the car lasts 100 miles without going low, but sometimes it goes low in 5 miles.
4. It seems to be tied to the heater, but then again sometimes i goes low fast when the heater is off.
5. Sometimes (often) when i pull up to stop lights I see steam coming out of the hood, but not billowing out. Sometimes this does not happen.
6. I do not smell coolant inside the cabin.
Any ideas? additional info needed?
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Did you ever have the system pressure tested? How long has this been happening? Was the heater valve ever replaced?
PEOPLE WHO TEST DRIVE A SAAB
USUALLY BUY ONE
Saab Owner/Driver since 1985,
photousa's Avatar
photousa photousa is offline
My Saabs: 2003 Saab 9-5 Aero Wagon 2.3T HO Manual
Sounds like a bad coolant bypass valve. The valve may by leaking on your catalytic converter causing the steam. The valve is only good for about 100K miles. You should get it fixed fast because if it completely fails while out on the road, the situation could cause an overheat, leading to a warped head and the need for a head gasket job. Your windows are fogging up because your defroster works in combination with your A/C. When your defroster kicks on, it also uses the A/C, so if the freon has leaked out of your AC system and it's not blowing cold, that's the cause of your fogging up.
Other things to check would be: Cracked or leaking hoses or a sticking/defective thermostat.
2003 Saab 9-5 Aero Sport Wagon >>> My other home:
2.3T HO B235R Manual 157,000 miles
My Saab Mechanic in Chicago: George @ G&S (773) 637-8431
africansky africansky is offline
My Saabs: 2000 Saab 9-5 V6 Wagon
Garage
Sounds like CBV to me, as well -- check if firewall is wet. Since you have V6, you may also want to check the oil cooler lid.
priapism priapism is offline
My Saabs: 03 9-5 aero wagon
Headgasket leak?
2002 9-5 wagon : Titan LE : SoCal Spec E30 #33 racer
Hey guys, thanks for the replies! I had it pressure tested a couple years ago which showed there as an external coolant leak out the head gasket. I posted about that a while back here. Most were certain that it was not the head gasket since it's rare for that to go bad, but quite common for the oil cooler cover to leak. I thought maybe the fog on the windshield may be a dead giveaway for another problem.
I did not see any coolant deposits on the engine between the 2 banks, as suggested in the other thread.
I paid $50 for the (likely wrongly diagnosed?) pressure test and don't want to have to go back and tell the tech I don't believe his first one, please sir, may I have another? Sure $50 isn't the end of the world, but it's a lot if you only get misinformation.
photousa's Avatar
Did you go to "Saab Tech", if so, not surprised they gave you a bogus evaluation and charged you $50 for it....
Yes, I do (did) go there. I see you are you in Chicago? any other recommended service shops?
Drain some coolant maybe and check it for goop. And check your oil for milkshakey looking stuff.
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
They wre nice to me, but did say the CV boot is ripped but repair was fairly priced. I was out of town but will look at it
Rarelibra's Avatar
Rarelibra Rarelibra is offline
My Saabs: 2004 9⁵ Aero "Griffin" Maptun̾
Garage
Saab Exchange in Lake Bluff is great, or Patrick Saab in Schaumburg.
I used to service my 9-5 and my wife's 9-3 at both with no issues.
unclemiltie's Avatar
unclemiltie unclemiltie is offline
My Saabs: 9-5 Aero's - 01 Wagon, 03 Sedan
Garage
your symptoms sound like something is leaking coolant INSIDE the cabin. heater core? or maybe the bypass valve is leaking and the coolant is running down and through the firewall.
But fog on the inside of the windshield indicates that coolant is leaking inside.
mecgmecg's Avatar
mecgmecg mecgmecg is offline
My Saabs: 2013 Audi A4 2.0T, 2008 9-5 2.3T BCB▓
Garage
Agreed.......
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Help. need to drain the coolant for the winter. Payne4life NG900 & OG9-3 Workshop 22 9th November 2012 05:35 PM
coolant temp sensor fails in winter eliot 9-5 Workshop 20 26th January 2011 09:35 PM
Questions- coolant, brakes, front windshield, door lock stpoolshark 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 24th February 2010 10:33 PM
winter coolant leak saabchilten NG900 & OG9-3 Workshop 0 16th January 2010 02:42 PM
Now that winter is fast approaching Big Ted NG900 & OG9-3 Workshop 0 16th October 2005 12:41 PM
