Dashboard warning lights - SaabCentral Forums
Old 31st October 2012
PMBOYD's Avatar
PMBOYD PMBOYD is offline
My Saabs: 2002 9-3 SE
Default Dashboard warning lights
Hey Saabers,
I have spent the whole day scouring the web for answers but can't find exactly what I need. So I was driving home from work today (in the pouring rain) and while I was going slightly uphill turning to the right I got an alert ding and my brake, TCS, ABS, and central warning light came on. I immediately stopped on a flat spot and turn my car off and on again and they went away. About 5 miles later when I was nearing home I was turning right, downhill this time, and all the the same warning lights came back on. I parked it in the garage and let it sit for a a long time but the lights remain on and I don't overly want to drive it with all the brake lights warning. I did notice that the breaking felt kind of funny on the drive home.
Any ideas what my next steps are before I break down and take it to someone who I'm sure will charge me lots of money?
I did just replace the pads and rotors a couple of months ago and I checked the break fluid and it seemed to be fine.
Thanks all
'02 9-3 SE, Stock for now, but won't be for long.
saabtwin saabtwin is offline
My Saabs: 9-5 estate & saloon & NG900 vert
It could either be the abs module or one of the abs rings at the wheels.
The module can be repaired (BBS Reman seem the best source) and you can drive the car with the module removed.
Have a look at the wheels and see if there is any damage or wear on the abs rings, should be easy to spot. Used rings can be fitted if necessary.
rameleg rameleg is offline
My Saabs: 00' Viggen Mike D Stg 3
did your speedometer also die when the lights came on?
PMBOYD's Avatar
So I will need to pull all the wheel tonight and check behind them?
And no the speedometer didn't die along with the lights (atleast not that I noticed) but I will check tonight after work.
Thanks guys
Old 19th February 2015
Mkhawam Mkhawam is offline
New Member
My Saabs: Saab 9-5
Hey I know this forum is from 3 years ago but I'm having the exact same problem for my Saab 9-5. All my warning lights turned on AND my speedometer turned off! Please help a brother out
lms's Avatar
lms lms is offline
Wrong Forum, but if all the lights are lit, and your speedo stopped working, its most likely the abs module. You can pull this off and send it to BBA for a rebuild.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
warning red lights on dashboard mariusift 9-5 Workshop 3 6th April 2010 11:53 AM
Dashboard Warning Lights bram 9-5 Workshop 4 12th May 2006 06:54 PM
dashboard warning light daveyellowconvert NG900 & OG9-3 Workshop 1 21st May 2004 06:09 PM
Dashboard lights, gearswitch lights - changing and parts? johkar 9000 Workshop 1 7th February 2004 03:21 PM
How to reset Dashboard Warning Lights??? asudds NG900 & OG9-3 Workshop 0 24th May 2002 09:44 AM
