Anti-Theft System Gone Mad -- HELP! - SaabCentral Forums
Old 4th October 2012
jotzgr jotzgr is offline
My Saabs: 89, 91 900T, 92 900S; 94, 97, 98 900S
Garage
Default Anti-Theft System Gone Mad -- HELP!
1994 Saab 900S. I have never activated or used the anti-theft system since I've had the car. This is the kind that does not have a key fob like my 98 900 Vert but where you turn the key 90 degrees to activate the system. I always just use the central locking (first detent) and the alarm has never activated. A couple weeks ago I came out and the car wouldn't start. I could hear the starter relay clicking, but nothing. I tried several things including cycling the driver's door lock and it started. Today I came out and same thing. I was 25 miles from home and I never could get it to start. There were no flashing lights or siren like the alarm had been set off. I was just about to call a tow truck when the anti-theft light in the middle of the dash starting flashing. The car then started and ran fine although the light is now continually flashing 24/7 whether the car is running, off, unlocked, or locked. I see in the owner's manual this indicates a fault in the system. I'm almost afraid to lock the doors again for fear it won't start. I also see there is a separate fuse just for the anti-theft system. Can I pull this fuse and deactivate the system entirely without it preventing the car from starting or affecting anything else? Should the car be running when I do that (i.e., Chrysler products). Any help would be greatly appreciated. Thanks.
earthworm's Avatar
Saab Sage!
Why not try to experiment ?
The car is a relic and not a daily driver ?, right ?
Do check out the battery and charging system, this task is easy enough..and when electrics are misbehaving, the first step..
I do not know if one can completely disconnect the security/alarm system on a '94 or 5..mine is a '96....I do not seem to have an alarm, I hope I do not
The earthworm
'96 900S, Automatic
Garage
It's one of my regular drivers and in excellent original condition. Looks almost new inside and out. The battery is 9 months old and the charging system is working properly. I definitely wouldn't call it a relic. Although after reviewing the system, the starter relay was definitely clicking inside the car and the lights were dimming when I turned the key to the start position, so maybe I have a starter going bad and the alarm thing is coincidental?
Garage
Pulled fuse #23, Burglar Alarm/Telephone. Everything seems to still be working properly. Car starts and runs fine. Central locking still operative. Flashing alarm light out. I'll see if problem crops up again; if so, most likely starter issue.
CleveSaab's Avatar
CleveSaab CleveSaab is offline
Saabista
My Saabs: 2006 9-3 SC, 2013 Volvo C70
Pretty sure you do. Don't think they came without the alarm system.
2006 9-3 SCombi
2013 Volvo C70
sankuspr's Avatar
sankuspr sankuspr is offline
My Saabs: 2005 9-5 Aero Sedan. Chilli/charcoal MT
Pulling the alarm fuse won't hurt anything. It will disable the alarm from activating/sounding when you open the doors, but not when you try to start it. There's a fail safe somewhere and I'm not sure where. Long story short I had alarm activated but fob batteries died. I opened the door with the key, pulled the alarm fuse. Thankfully the alarm shut up. Put key in ignition and tried to start the engine. This is where I nearly jumped out of my skin. The engine cranked and pretty much started, then shut right off (alarm did that). At the same time, the alarm resounded even with the fuse pulled. So basically pulling the fuse allows you to get in and out without it sounding but won't stop the alarm system from disabling the engine.
As to turning the key 90degrees in the vert- that's just the deadlock, not the alarm. I use that now that my alarm won't really respond even with new batteries. Btw, the deadlock just doesn't allow the doors to be unlocked Cept with the key from the outside. Even lifting the lock won't work-it'll just pull back down right out of your grasp.
It really is that simple.
Old 5th October 2012
wal wal is offline
My Saabs: 85,92,98 900
Default You may want to look at this post...
http://www.saabcentral.com/forums/sh...d.php?t=236919
Old 8th October 2012
jitsjaf2009 jitsjaf2009 is offline
My Saabs: 1999 Saab 9-3 SE 2.0 ltr Convertible
The fuse was my solutuin to the same problem. I have been driving for two years now without this fuse and no problems. My 'relic' is a daily use vehicle and I 'love my Saab'.
Pontius DIO Pontius DIO is offline
My Saabs: .
I grabbed an extra alarm assembly for $5. It's under the drivers-side fender near upper door hinge (pull fender liner and it's right there). Both batteries in it were showing 3v with volt meter so I'll eventually swap into my alarm as the warning has been popping up. (looks like batteries are soldered for some reason) Very rare that people take the alarm from bone yard cars. Very easy to remove. The yard didn't even know what to call it, so they sold it as a "horn" LOL. You can't even get the batteries for $5 new!
Old 21st March 2014
huntz huntz is offline
New Member
Default jotzgr
I am having the exact same issue with my saab 9 3 not starting. I hear the clicking as I insert key, the lights come on but won't turn over at all, just as you described. Did you ever determine the problem? I am anxiously awaiting your reply as it sits in the parking lot.
Old 21st March 2014
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Have you tried the simple things first, like checking the battery voltage which should be at least +12.6 VDC, then trying another key?... Ron
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
anti theft system failure cobra989 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 2nd September 2010 07:25 PM
help me please anti theft system edhunter C900 Workshop 4 3rd March 2009 05:45 PM
SAAB Anti-Theft System, remote control ben900 C900 Workshop 4 31st May 2006 05:54 PM
anti theft system fishnut 9-2X Workshop 2 7th May 2005 05:31 PM
anti-theft system locked on Bagel NG900 & OG9-3 Workshop 6 4th February 2005 01:43 PM
