Help! Radio wont turn on, and turn signals dont click - SaabCentral Forums
Old 27th September 2012
hotsizzlesauce hotsizzlesauce is offline
My Saabs: 2004 9-3
Default Help! Radio wont turn on, and turn signals dont click
Hello
I started my car kinda quickly, and went straight into drive not long after turning on the engine... I'm not sure if that had anything to do with it
I noticed that the disc player wasnt starting... (I turned it off with it still on...) then I tried pushing the radio button to tuirn it on, and it wouldnt work. I have turned off the car once and re-tried, but still not working.
The blinkers/signals also are not clicking when I use left/right or panic.
Help! Anyone know what has happened?
Ugh...
katanamaster katanamaster is offline
My Saabs: 2003 9-3 Linear
Garage
I did the same thing I believe that you did. Look for the fuse box next to the driver seat and open it. Grab the fuse puller and look for a yellow fuse in spot 14. With the car turned over (car isnt running, just the accessories working) pull the fuse and put it back in. You might see a small spark but its ok.
Let me know if this works. Solved my problem and I hope it will solve yours.
Edit: I swapped the yellow fuse for the extra fuse that was on the panel but both fuses looked to be in working order.
My Saabs: 2004 9-3
Update: was just about to try above, but I turned on my car again and it seemed to work itself out again.
Thanks! (wasnt even sure where the fuse box was...)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Radio/CD/AUX/ Turn Signals Don't work Anteneh 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 31st May 2012 09:27 AM
radio botton backlighting wont turn off drebinpk 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 9th February 2012 03:24 PM
No power to aftermarket radio, turn signals or windows tuttiface 9-5 Workshop 3 1st June 2010 07:02 PM
Battery died and Now Turn Signals Dont Work? sailorcolin NG900 & OG9-3 Workshop 1 8th January 2010 01:28 AM
No Radio, No Turn Signals, No Speakers 06AeroTurbo 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 33 26th November 2009 02:29 PM
