Tyre pressure: never guessed! - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 16-03-04
Oliver Oliver is offline
Location: '95 CSE 2.3T - Golf MkI conv. - a pair of C900's in boxes
Default Tyre pressure: never guessed!
Never guessed how a subtle change in tyre pressure could make such a big difference in handling!
I increased rear tyre pressure up to 2.8 bar (which is on the high side, I know) and kept the front at 2.6.
Result! Understeer has virtually disappeared, the car's perfectly neutral in any of the situations I've thrown at it! 8)
Tomorrow I'm going to try and depressurise all the wheels by .2-.3 bar to increase traction...
Any thoughts on ideal tyre pressures front/back?
Old 16-03-04
Johann F Johann F is offline
2.8 bar is dangerously high for a tyre - about 42 PSI!!!. Try 32/36. If you remove your front ARB you can run equal pressures and have neutral steering.
Old 16-03-04
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
That LPG kit must weigh a bit though - I can't recall offhand the recommendations for rear tyre pressure when fully laden, but it was surprisingly high. I currently run 32psi front, 34 rear, but the front seems a little soft. Owners manual I believe says 30 front, 32 rear, but that's way too soft.
Old 16-03-04
In my 91 handbook it gives 2.7bar as the maximum for the rear at maximum load and above 100mph. If you are not loaded up you are loosing a lot of grip with high tyre pressures. The answer is stiffer side walls from lower profile tyres on bigger rims or just uprated tyres in the V rating (or both)
Old 16-03-04
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Maximum tyre pressure is embossed on the sidewall. Make sure the current pressure isn't in excess of this.
You'd be surprised how high tyre pressures get during a long motorway cruise
Old 16-03-04
Nah the tyres said 3 bar max.
And even now when looking at the car it's like the tyres are way too soft. :-?
Oh and I took a look at removing the front ARB for improved handling... I havn't got one.
As I said, tomorrow I'll lower all of the wheels by .3 bar, which should give 2.3 front and 2.5 rear.
Oh for you imperial lot that's 34-ish front and 37.5 rear.
We'll see how it goes then.
Cheers
Old 17-03-04
If you haven't got a front ARB to remove you are 1/2 way there - it's very easy to add a rear ARB to do get the same result.
Old 17-03-04
Alex's Avatar
Alex Alex is offline
My Saabs: 3dr c900 T16RA, 9-5 Aero Estate
Different makes of tyres have considerably different sidewall stiffnesses. Bridgestones typically have stiff sidewalls, the Falkens I used in the past were way too soft to be used on a Saab, and the Goodyear Eagles are roughly midway between the two.
Old 17-03-04
They're Firestone's.
