Full range door speakers? - SaabCentral Forums
Old 22-09-12
Siguii Siguii is offline
My Saabs: 1996 900SE 2.0L Turbo
Default Full range door speakers?
Would it be worth it to swap out the low range amp and door speakers with full range ones in my 900SE? I care more about audio quality than anything, but something tells me that the acoustics of the vehicle wouldn't allow me much benefit from full-range vs. low-range speakers when they're mounted at floor level.
Also, what's the box behind the trunk lining, where the clarion changer (which I don't have) plugs in? Is it an extra amp, or what?
Old 23-09-12
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is offline
My Saabs: 1997 900SE Talladega coupe
My family's had several Honda Civics with full range speakers down low in the doors, right where the woofers are in our Saabs. I was never impressed with how they sounded down there. The balance was always off, and the treble didn't project well. If you want to replace the amp with a full-range one, I'd put a low-pass filter on it so the door speakers still only get bass.
I'm not sure what other box you're talking about behind the trunk lining. The only thing that should be back there is the power antenna motor, unless you have a convertible. I think they have a computer for the top back there, too.
Old 23-09-12
Well, it's not a convertible, just a 5-door SE. The box is mounted a little bit forward of the antenna motor, right below the rear speaker. I had assumed it was hardware related to the CD changer, but I suppose it could also be an amp for the rear speakers? It seems to be a factory part.
Old 23-09-12
earthworm's Avatar
Saab Sage!
Since we have an old car here with an unknown history...I'd guess that at one time the mystery trunk bracket held the CD player - years ago..
On audio quality, I do not think that any vehicle can be good at this...there is so much audio compromise....only a true concert hall with a proper design will do.
Or a superb pair of headphones, IMO..
The earthworm
'96 900S, Automatic
Old 23-09-12
win_k win_k is offline
My Saabs: 99 9-3 SE, 99 S Coupe, 01 SE Vert
The aux amp that drives the front door speakers has an active crossover built into it that kills all but the bass. Full range speakers won't ever get the higher frequencies
On the up side, the old oem woofers might well be getting quite tired (the foam surrounds are notorious for failing) and full range speakers are much easier to find and make perfectly adequate replacements.
Old 23-09-12
Well I'm not sure why the CD changer would be in a sealed aluminum box, INSIDE the trunk lining.
As I said, I'd be swapping the amp out as well. Door speakers aren't currently working, dunno why. Just fixed my SID so I can finally use the radio again.
Old 23-09-12
Okay, I removed the lining to take a look at said box again... It's about 5 inches on each side, has a couple coax cables leading out of it, and an unused 8P8C connector. What the heck is it?
Old 23-09-12
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
My Saabs: Black on black '97 Saab 3-door SE Turbo
It could be a transceiver from an old analog cell phone... Ron
Old 23-09-12
So... Back to the original topic at hand. Which option out of the following should I pick?
New receiver, small amplifier for door speakers (possibly new door speakers as well) and stock rear and dash speakers
-or-
New receiver connected directly to new component speakers, tweeters in place of dashboard speakers, and no amplifier
Old 23-09-12
crispin9-3 crispin9-3 is online now
My Saabs: 99 9-3 vert
Garage
-or-
or
C: Factory radio
Component front speakers, 6.5 in doors, tweeters on dash
100 watt x 2 quality amp running the front speakers
Old 24-09-12
Originally Posted by crispin9-3 View Post
or
C: Factory radio
While I would like to keep the factory radio, as it sits flush with the dashboard, the lack of a CD player or aux-input (granted, the latter I could fix easily enough) is a bit of a drawback for me... The tape deck doesn't even work on my unit. I feel like it'd be better to get a new radio.
Old 24-09-12
jakejm79's Avatar
jakejm79 jakejm79 is offline
My Saabs: 1999 9-3 Convertible
If you want a new headunit, I would do components in the front (the doors are too low a location to locate full range speakers) drive those with a new 2 channel amp and then drive the 3-way 6x9s in the rear with the headunit it, unless you want to spend the extra on a 4 channel amp.
Old 24-09-12
What brand/model would you recommend for component speakers?
Old 24-09-12
jakejm79's Avatar
I have Hifonics in mine, great for the price, but there are plenty of choices depending how much you want to spend.
Old 24-09-12
I don't have all that much to spend, but I care far more about audio clarity and dynamic range than power/booming bass... I am a bit of an audiophile, but of course can't be too extravagant... Even if I did have thousands to to spend on car speakers, I'm not sure I'd install them in my $500 Saab...
Generally speaking, if a product is the best "value" within a certain price range, I'll get whatever is the best "quality" within the same price range, provided that it's within 10-20% of the price of the "value" model.
Old 24-09-12
EdT EdT is online now
My Saabs: 1997 Saab 900 2.3 Coupé
Your car should have the control cable for a CD changer running to the back already. So if you can find a Saab (Clarion) changer in the junkyard, you have CD with your existing head unit. May not cost much either.
The factory dash speakers are not very good, and the rear factory 6x9s will probably have rotted foam, and they weren't very good in the first place.
The factory radio had already been replaced by a crappy Sony Xplod so I put in my Blaupunkt head unit.
I had a pair of good (Boston Acoustics SL95) 6x9s on hand, so I dropped them in the back, and drove them with a small power amp I have. I ran the dash speakers off the head unit. They weren't very good, so got replaced with the best pair of drop-in 3.5s I could find (Kicker; would have gone for Boston Acoustics but BA is out of the car audio game). This produces a pretty effective sound overall, though the enclosure for the 6x9s isn't good enough for really clear deep bass.
If I get around to it I might put in some door speakers (my car didn't come with them), but the additional complexity in wiring and amplification is dissuading me. The system as I have it is competent and will play nicely loud without being annoying. The soundstage is kind of surround, though, instead of being from ahead. I don't mind, but some people do.
Old 24-09-12
I saw a clarion for pretty cheap on eBay, and considered buying it, but it seemed to me like having to access the trunk to put a CD in would be inconvenient.
I have seen some used Saab CD receivers from 9000, 9-5, and 9-3s... Are those compatible with my 900? Or is the wiring all wrong?
Old 24-09-12
jakejm79's Avatar
You may be able to get the one from the 9000 to work, but the newer ones (9-3 and 9-5) are married to the car and wont work with a ng900.
The changer in the trunk is 6 disc, so you wont have to change that often, I do have one I don't use if you want it, but I think a new headunit is a better decision as its nearing 15 years old now. And where in MA are you siguii?
Old 24-09-12
Near Amherst.
Old 24-09-12
jakejm79's Avatar
OK I'm about 2 hours away, but if you are ever in the southern NH area you are welcome to come listen to my setup.
Similar Threads
Front door speakers (Kicker 10CVT65), and door wiring cdies Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 18 21-09-12 01:22 AM
HELP - All speakers work accept door speakers bluh5d Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 2 24-02-12 09:08 AM
Is it true that the dash speakers are fed the full range? 3rigel Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 4 13-09-11 03:03 AM
Full audio range to door speakers on 9-3 sandraqu Saab 9-3 & NG900 Workshop 0 04-09-11 02:21 PM
Full range signals for my Components volcomstone2262 Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 3 13-02-09 05:16 PM
