Steering lock malfunction, key won't turn in ignition - SaabCentral Forums
Old 12th September 2012
LON619 LON619 is offline
My Saabs: 02 9-3 2.2tid
Default Steering lock malfunction, key won't turn in ignition
Was working on the car on Saturday, disconnected the battery and got the brackets welded on the rear for my airbags, went to start the car on Sunday morning and this sid said steering lock malfunction contact service and won't let the key turn at all
I've tried: Disconnecting the battery overnight
Removing fuses 1&2 for a few seconds to reset ignition and lock
Resyncing the key
Tested every fuse I can see in the car
New ignition switch
A fully charged battery
All of which didn't make a difference, anyone had this fault before tried anything else
Could the key have lost its programming? I've someone calling to my house this evening to plug tech2 in but if there's something I could try in the mean time to save him calling out
Thanks
Bryce804's Avatar
Bryce804 Bryce804 is offline
My Saabs: 2006 9-3 Aero 2.8t
Garage
This may be obvious, but you didnt say you tried. I used to get this same failure on my 06 aero. As I was inserting the key and attemping to turn it I would rotate the steering wheel back and forth. This would allow the steering wheel lock to free up.
the steering wheel lock can go bad also.
2004 9-3 Aero 6am black
2009 Jaguar XFSC vapor grey
2006 9-3 Aero 6sp silver-sold
Yea I tried that too but still the same, the tech2 man should be here in about an hour so will hopefully find out then
So tech2 fixed it, not sure what he done but 1 hour later the car is back to not working again, stupid thing is so annoying
Old 14th September 2012
skyeagle's Avatar
skyeagle skyeagle is offline
My Saabs: 2007 Saab 93 2.0T
I've had this issue plenty of times and finally now been few months without anything! Where you place the key you will hear a click every time you turn it. That module I removed and started looking in it. There are two metal pieces that every time you turn the key it contacts with 2 other pieces. Over time I guess with our saab's those two pieces stretch and no longer reach the contact SOOOO I pushed the hell out of it down so there is no way possible it would not get contact and ever since then its perfect!
Got it fixed the computer lost the key code so wasn't recognising the key
Got tech2 plugged in for 20
Old 24th November 2014
LUBIANO991 LUBIANO991 is offline
New Member
Hey im having the same problem, and saab wants to charge me 2000dollars to fixed it. Can you give me a call please
Swededemon Swededemon is offline
My Saabs: 2003 Saab Vector MPS tuned
They want to replace your CIM. There is no need for that unless they have ruled out the other options first.
Maybe give this a whirl: http://www.saabcentral.com/forums/sh...d.php?t=373298
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Steering lock malfunction Stecompo NG900 & OG9-3 Workshop 4 15th October 2011 07:41 AM
Key remote, steering lock malfunction, stability control malfunction faults!!! NewbySaabOwner01 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 29th December 2009 06:38 PM
steering lock malfunction mcscholz 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 26th January 2009 05:43 PM
Steering Lock Malfunction danielle93 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 5 5th March 2008 12:52 AM
Ignition Lock Malfunction Molitoth 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 7 9th August 2004 07:50 AM
