Home Saab Pictures Saab Classifieds Saab Dealer Listings Saab Forum
Go Back   SaabCentral Forums > Saab 9-3 Sports Saloon/Sedan/Convertible/Combi > Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop
Old 12-03-04, 12:54 PM
Viscouse's Avatar
Viscouse Viscouse is offline
My Saabs: 2003 9³SS Arc, 100k+ miles
Default Question for Entertainment: Speed-dependant Volume
Entertainment, as our resident expert, do you know why the Speed-dependant volume feature doesn't seem to work as well as expected?
Is it working, as some of us have theorized, but changing audible things (we'll think it's louder but doesn't seem that way)
Is it not implimented? Or maybe on certain models?
What's the scoop? I would hazard a guess that many of us don't feel it's working at all, even when tested on all 4 settings (off, low, med & high).
Here's some previous discussions:
http://www.saabcentral.com/forums/viewtopic.php?t=14045
http://www.saabcentral.com/forums/viewtopic.php?t=12394
Old 12-03-04, 03:17 PM
ctrlz ctrlz is offline
Moderator
Location: Ocean City NJ, 03 Vector 2.0T 6spd, BSR Stg 1
Default SDV???
Great question for the Guru!
I agree this feature is either VERY subtle, or vaporware.
Old 15-03-04, 01:34 AM
flip_man flip_man is offline
Default Re: SDV???
My vector just keep on reset it after a few starts...
Old 15-03-04, 02:55 AM
AirTreesWaterAnimals AirTreesWaterAnimals is offline
Doesn't work at all in my '04 Aero.
Old 15-03-04, 03:11 AM
Larakin's Avatar
Larakin Larakin is offline
My Saabs: 2003 9-3 Arc 2.0T 6-Spd
Default Re: SDV???
I have the exact same problem '03 Arc
Old 15-03-04, 06:19 AM
Entertainment Entertainment is offline
The Speed Dep. Volume should work perfectly, it did at least when I tested this couple of years ago. I never heard that there would be any problem with this function.
My suggestion is to go back to the dealer and complain, because this should be reported back to Saab immediately.
Old 15-03-04, 07:26 AM
orion7144 orion7144 is offline
I think it does work... But I think it works too well.. In the BMW you can tell at certain speeds that it increasing and on some other models it is just downright annoying. Ours on the other hand adjust the volume smoothly to were you can not tell it is increasing. By using a db meter (One that I use to calibrate my home theater) there is an increase but it is not that big. If I remember correctly my 3 series I got almost a 3db gain when at 50-60mph. That is 3db all at once. On the Saab it is more like 3db gradually hence why some people think it is not working.
Old 15-03-04, 09:04 AM
The 9-3SS has 20 different curves for Speed Dep Volume compensation, while other cars maybe have 2-10 curves and then there is Speed Dep Bass compensation (including Engine On Bass compensation).
So therefore the function is hard to notice in action.
Old 15-03-04, 10:02 AM
Viscouse's Avatar
Thanks Entertainment!
Hmmmm. Is there any way to test it? I've brought it up to my dealer & they say it is working fine.
Old 15-03-04, 12:12 PM
Larakin's Avatar
It does work, but only for a few starts (i dont know how many), whenever I notice it is not working I check and the setting has been turned off. This happend very frequiently, not a big deal at all one of the many small annoyances. but I still love my car.
Old 15-03-04, 12:17 PM
Yes if you can simulate the Vehicle Speed signal on either CAN or MOST :wink:
The only simple way that a normal customer can test this is by a subjective listening test with the function On and Off. This way you should be able to hear the difference.
Old 15-03-04, 01:12 PM
brunp's Avatar
brunp brunp is offline
My Saabs: none
Perhaps the only way to test this functionality is to be traveling 100 km/h and stop very quickly....you will notice that the sound volume decreases.
That is how I noticed it on my previous Volvo S40...
Paul
Old 15-03-04, 01:19 PM
Moderator
Default Initial volume setting affect SDV?
Entertainment,
Do you recall the amount of gain offered by the various curves? Also does the initial volume setting have anything to do with the function of SDV? When I was playing with the settings it seemed to work at low volume. But when I turned up the volume it seemed to do nothing.
ctrlz
Old 15-03-04, 03:14 PM
rdenotter rdenotter is offline
I've done some careful listening, and I'm convinced that it does work -- especially at low volumes.
What I'd like to know is why does it seem to turn itself off after a while?
- Is this related to time?
- Is this related to on/off cycles?
- Or, (more likely IMO) is it related to my hitting the volume button on the steering wheel?
I can't be sure, because it's hard to reproduce this, but it seems like when I manually adjust the volume when SDV is set, it goes into some kind of polite mode where it backs off, and then shuts off entirely.
Entertainment? Any insights?
Old 15-03-04, 08:35 PM
Default Re: Initial volume setting affect SDV?
Entertainment,
ctrlz
No I don't remember the gain for the different steps, sorry.
The higher the volume is, the less compensation there will be and at volume step 25 (of maximum 30) there is no more compensation.
If the SDV turns Off completely, then it looks like some kind of bug. I've never heard about this fault before.
The problem is that all of the experts that used to work with Entertainment system has left that department (or Saab), including me. So there is nobody who can handle these functions (that good) left at that department.
Old 15-03-04, 09:35 PM
CosmicSaab CosmicSaab is offline
Why'd everyone leave? Do they not need entertainment system designers anymore?
Old 16-03-04, 01:12 PM
One quit and started up his studies again, one got fired 1,5 years ago, I left 9 months ago when my contract ended and the last one left 5 months ago when his contract ended.
Old 16-03-04, 10:50 PM
sbl sbl is offline
My Saabs: 2003 9-3 SS Arc
I complained to my dealer about this, and they promised to investigate and get back to me. Haven't heard yet. The SDV definitely does not work for me, or if it does, it changes the volume impercetibly. I always have to raise the volume as I accelerate onto a highway.
Old 16-03-04, 11:15 PM
Same here. I messed around with it in my car and had no success whatsoever.
If it does work, it's not really serving it's purpose.
Old 17-03-04, 01:43 PM
Moderator
Default detecting sdv at work
Try this. Set the SDV to "high." Then drive around with the volume at conversational level or a little lower. That's how I detected it working. It's subtle to almost to the point of being useless. Jari says the gain tapers off at higher initial volume. So maybe at low volume you get 3 dB of gain, and at high volume you get 1 dB. Beats me why they bothered coming up with 20 curves to handle this little adjustment.
copyright © 2003 saabcentral.com, All rights reserved - website by WDD serviceshttp://www.whiter.co.uk - valid xhtml - valid css
SaabCentral is an independently run website and is not affiliated in any way to Saab Automobile AB
