Stage 5 on OEM plugs? - SaabCentral Forums
Old 10-08-12
Saabonthis Saabonthis is offline
My Saabs: 2 door 99 9-3
Default Stage 5 on OEM plugs?
Just picked up a 99 saab 93 with a JZW stage 5 tune. Has the jakstoll t25/t28 turbo, bigger intercooler, green giants, 3in dp and exhaust. Only issue I seem to be having is after 100+ miles it starts to misfire under full boost (27psi). It goes away when I replace the plugs. I'm wondering, maybe I should switch to a colder or hotter plug? And recommendations?
Old 10-08-12
Fox Fader's Avatar
Fox Fader Fox Fader is offline
My Saabs: '98 900SE Manual
My first question would be about the tune or maybe ask JW.
You running an A/F gauge?
Old 10-08-12
No a/f gauge yet. That will be one of my first items to get. However, after checking the plugs they are a light tan color.
Old 10-08-12
saabkid37 saabkid37 is offline
My Saabs: 99 Viggen
what plugs are you using.
Old 10-08-12
grkguy89's Avatar
grkguy89 grkguy89 is offline
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Garage
^this
AND
what are the plugs gaped to?
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 11-08-12
Well I just installed ngk iridium ix plugs. They are gapped at .040. New plugs didn't help the misfire/sputter. Drives just fine otherwise, just when you hit 15psi+ it starts to act up. The plugs before were some cheap bosch ones, it ran perfect for awhile. Gap was the same on those as well.
Old 11-08-12
My Saabs: 99 Viggen
It's very possible the non ngk plugs blew up the di cassette.
Old 11-08-12
Anyway I can test the di?
Old 11-08-12
tomipee tomipee is offline
My Saabs: Ng900 Turbo
You should try with another dic
Old 11-08-12
losacker losacker is offline
My Saabs: 1999 Saab 9-3 2 door (Full pressure)
i would go with the original resistor plugs instead of the iridiums. and the gap should be .039, not .040. especially with higher boost you might be blowing out the spark with the longer gap.
Old 11-08-12
grkguy89's Avatar
Moderator
Garage
at stage 5 gap them tighter than that... closer to .033-.034
Im gaped at .030 on my stage 6
Old 11-08-12
I'll lower the gap down a bit and see if that helps at all. Also I do not have a rear o2 sensor. I have replaced the front with a universal bosch. However, I'm getting that p0135 code. I've checked fuse 38, and it's good.
Old 11-08-12
swedishrocketng900se swedishrocketng900se is online now
My Saabs: 97 900se, 97 9000 cse, 03 95 aero
Are u running a red or black dic ? ive heard that for the higher level tunes that t5 should run on the red dic just a thought idk how true it is though
Old 11-08-12
I'm using the red top di
Old 11-08-12
AZR Racing AZR Racing is offline
My Saabs: 1997 saab 900se
Garage
t5 should run the red DIC regardless. you can run the black DIC on a t5 but its not reccomended due to the lack of some components, like a knock sensor. stage 5 tune and no wideband... this is a recipe for disaster. you could be leaning out really bad. does this car have a 3bar map sensor? what color are the plugs when you pull them out.
900 SEC 2.xT, custom 3inch exhaust, GT35r BB turbo, custom log manifold, tial Q bov, autometer phantom boost,oil,WB, JZW full custom tune, siemen 60# injectors, aeromotive 340 intank, want fried rice?
Old 12-08-12
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5
Garage
I run NGK's 7's on my stage 5, Gapped to 0.9mm.
Use the cheap NGK BCPR7ES-11 copper plugs, Our motors love them.
B.L.T.H.....Brake late Turn hard
Old 12-08-12
^i use those too, no problem. Many uses those ngks here in finland, good plug for these engines. Doesnt last for years i think, but those are cheap
Old 12-08-12
Okay, well after checking the plugs, they are a light tan color. Also I turned the psi down to 20psi and put the plug gap at .030 and so far it's not misfiring.
Old 12-08-12
My Saabs: 99 Viggen
time out. if you turned down the boost it sounds like your using an mbc with an ecu tune...which is a no no.
Old 13-08-12
bogan's Avatar
Garage
I change my plugs every second oil change and re-gap every oil change.
Yeah, How did you turn your boost down?
Similar Threads
correct spark plugs for stage 4 ish 9-5? mgmt585 Saab 9-5 Workshop 13 26-05-10 05:17 PM
spark plugs for stage 1? skid9uk Saab 9-3 & NG900 Performance, Mods & Tuning 6 30-06-08 11:56 AM
Saab 9-5 2.0 LPT BSR Stage 1 - Spark Plugs? aaronh21 Saab 9-5 Workshop 2 19-06-06 08:47 AM
recomended spark plugs for stage 3? WaSaabiPSI Saab 9-3 & NG900 Performance, Mods & Tuning 5 31-05-06 08:05 AM
Freeze plugs / core plugs Dninty9 Classic Saab 900 Workshop 1 13-06-03 04:06 PM
