No Start - SaabCentral Forums
Old 24-07-12
jt20 jt20 is offline
My Saabs: 91 900 na
Default No Start
217k miles '91 non-turbo LH 2.4.2
Pump works and can pressurize the rail with a jumper between fuses.
Pump relay works - tested
.013V across pins #85 and #86 on the pump relay pins when cranking - not sufficient.
Ground signal is present @ pin #17 on the LH Control Unit harness.
It appears to be the control unit, Correct?
Old 24-07-12
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
Is there a spark? No spark = no fuel.
Old 24-07-12
My Saabs: 91 900 na
Thank you. I will check the ignition system tomorrow.
What is the common failure by 200k miles? Coil, ignition control unit, hall sensor etc..?
Old 24-07-12
Impossible to pick one above the other. They are all known to often go on forever. Saying that, the CPS (Crank Position Sensor), which is the hall sensor at the rear of the crankcase is known to fail occasionally.
Old 28-07-12
My Saabs: 91 900 na
There is no spark. From a functioning, non-turbo '93 I swapped the EZK unit, amplifier and ECU - still no start and no spark.
What clever ideas do you folks have for rotating the crankshaft with the engine in place? It appears to be impossible after many attempts.
Following the FSM:
Knock sensor - good
power to EZK unit - yes
Power to amplifier - yes
power to coil - yes
coil resistance - good
amplifier switching - could never get 0.0V but the current amp had the same behavior as a known working amp
pulse signal from EZK - good
Hall sensor - can not check due to crank rotation.
Old 28-07-12
Jim Mesthene Jim Mesthene is offline
How did you determine that? It's not easy to measure. Is there a pulse at the coil?
Your symptoms match those of a failed Crankshaft Position Sensor. The tests described in the manual are always inconclusive, don't even bother with them. Look for a Primary ignition pulse while cranking.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 28-07-12
My Saabs: 91 900 na
You are absolutely right. Without an oscilloscope, I had to default to a multimeter and the average was approx 2.8v
I see what you are saying.... but what is "Primary ignition pulse" Is that the 'quick test' by pulling a plug and grounding it?
I did that - no spark.
Is there a recommendation for testing the CPS, or just replace it...?
Old 28-07-12
See if the primary side of the Coil (the little wires) show pulsing voltage. The Hall Effect Transmitter (whether on the crankshaft or in the distributor) sends a signal. Try to find it after it has been amplified.
Old 05-08-12
ragtopper1994 ragtopper1994 is offline
My Saabs: 1994 900s Convertible
I am having the same exact problem with my 94 vert, but adding to the mystery is that the wire harness that runs past the shifter burned up and shorted several wires. All of the wires have been replaced and rechecked. I have not checked for a pulse signal but will do this ASAP. There was a condenser wired between the coil and distributor but the wire is broken. Is this for radio noise reduction or is it required for normal engine operation?
Had my hand on the phone several times to call the junk yard to come and get it but I just can't seem to let it go.
Old 05-08-12
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
don't junkyard it sort it, but even if you want to get rid of it sell it someoe will give it a go, and give you more than a junk yard
22saabs
Old 18-11-12
My Saabs: 91 900 na
Just an update.
Replacing the CPS via the tutorial on this site got the engine running again. There are other issues, but we solved the big one.
Thanks to all!
Old 18-11-12
QuickOrange's Avatar
QuickOrange QuickOrange is offline
My Saabs: '92 900S, '93 900 Turbo Vert
Funny how that little sensor can cause so much trouble.
'93 Saab 900 Turbo Vert: New project...
'92 Saab 900 S: My first 900 and what a beauty
'90 Chevy 1500, Stepside: Ongoing project, future recipient of a 400HP LS2
'00 Kawasaki Ninja 500R
Similar Threads
Engine stalls alone or do not start. After some minutes start fine. dacer Saab 9-3 & NG900 Workshop 3 16-02-13 01:28 AM
Refusal to start, then hard start, then finally starts - why? Kyle86 Saab 9-3 & NG900 Workshop 1 08-09-10 12:36 PM
2001 9 3 Intermittently Won't Start. power, no ignition start. vpialums Saab 9-3 & NG900 Workshop 4 28-09-08 02:32 PM
Cough & splutter on start up. Cuts out. Will/wont re-start. GONE FISHING Saab 9-5 Workshop 3 06-08-08 05:10 AM
No Start; Start - Weird Idle; No Start; Start - Runs Fine Black Beauty Classic Saab 900 Workshop 3 22-08-05 09:10 PM
