New here? You want more power? Read here FIRST. - SaabCentral Forums
Old 18-07-12
comtrang's Avatar
comtrang comtrang is offline
My Saabs: 1997 900SE Holset HX35 4??bhp
Garage
Thumbs down New here? You want more power? Read here FIRST.
DISCLAIMER: I did not force you to go out and get yourself in trouble while behind the wheel of your car after doing these things to it. Be careful when behind the wheel, do not let your friend drive once your Saab is transformed into a rocketship after reading this information.
If you're here to any of the following questions:
"How do I get more power from my Saab?"
"Which turbo should I get?"
"How much horsepower will I make if.....?"
Keep reading.
For those of you who have other questions, USE THE SEARCH FUNCTION BEFORE MAKING A NEW THREAD. More than likely you will find the answer you are looking for.
If you've been on here for awhile, you may have noticed that a lot of the same questions pop up over and over so I'll try to be as clear as I can in this thread with the different possibilities that await you and your newly found love. A lot of it is common knowledge but maybe not for some. People were there for me when I had questions and since then I've just tried to pay it forward as best as I can so I hope this helps some of you who are new or even if you've been around a little while. Here goes.
Note that most of this applies to MANUAL transmission vehicles.
The Turbocharger
For those of you who are completely new to the world of engines, turbochargers and tuning I highly recommend these links to begin. They are simple yet concise explanations to give you the basics.
How Engines Work - www.howstuffworks.com/engine.htm
How Turbochargers Work - auto.howstuffworks.com/turbo.htm
Generally speaking, the purpose of the turbocharger is to 'recycle' exhaust gases coming out of your engine, using them to spin a turbine wheel on one side of the turbocharger before exiting out through your exhaust system. This turbine wheel is directly connected to another wheel via a shaft in between them. The purpose of this second compressor wheel is to compress the air it intakes when spun at really high speeds. Compressed air means more dense, meaning more of it can fit into a space. This compressed air is then routed through the intercooler where it is cooled and then fed into the throttle body.
In short: exhaust gas comes out of your engine feeding into the turbo, spinning the turbine wheel and, in turn, spinning the compressor wheel which compresses air allowing you to fit more of it into your motor. This, combined with the appropriate amount of fuel, makes more power. The larger the turbo and its exhaust/compressor wheels, the more exhaust/rpm needed for it to reach peak 'boost' thus the rpm at which peak torque arrives is shifted to the right on the scale.
Now back to Saab.
If you've got the following model, then:
1994-1998 Saab 900 2.0 Turbo - Garrett T25
1999 Saab 9-3 - Garrett T25
185bhp - 2.0L B204L
1999 Saab 9-3 HOT - Garrett T25
200bhp - 2.0L B204R
1994-1998 Saab 9000 Aero 2.3 - Mitsubishi TD04-15T, 6cm^2 exhaust housing
225bhp -2.3L B234R
And in some markets,
1994-1998 Saab 900 2.0 Low Pressure Turbo - Garrett T25
155bhp - 2.0L B204E (differs from a B204L - lack of Boost Controller (BPC) and different software)
T5 Engine Management - MAP sensor
2000-2002 Saab 9-3 Base - Garrett GT17
185bhp - 2.0L B205L
2000-2002 Saab 9-3 SE HOT - Mitsubishi TD04-15T, 5cm^2 exhaust housing
205bhp - 2.0L B205R
1999-2002 Saab 9-3 Viggen - Mitsubishi TD04-15T, 5cm^2 exhaust housingj
225bhp - 2.3L B235R
2000-2002 Saab 9-3 Base 2.0 Low Pressure Turbo - Garrett T17
150bhp - 2.0L B205E (differs from a B205L - different software)
T7 Engine Management - MAF sensor
Yes, they're all interchangeable and you can put a TD04-15T on your 1994-1998 900 or whatever you like, but we'll get to that. The flange on all of these turbos is of the T25 designation, not to be confused with the actual Garrett T25 turbo.
Also, if you pop your hood and you see a RED cartridge on the motor that says Direct Ignition, you have T5 engine management. If it is BLACK, you have T7. Do not interchange these cartridges with ones of a different color.
But wait, first can I run outside and stick a blow off valve on my car?
Before I really get going, I want to make it clear from the start because I know someone is going to ask.
YOU CANNOT USE A BLOW OFF VALVE ON T7 CARS. Period. For those T7 owners who want to upgrade from their fault stock bypass valve, Forge offers a nice aftermarket unit that recirculates back into the system as it should. There is no way around this as of today but with further tinkering in T7suite, someone may come up with a trick.
BOOST DOES NOT EQUAL HORSEPOWER
One last thing I'd like to make clear before going just because it annoys me pretty bad when I hear it. If you're boosting 30psi on your stock T25 and your friend is only boosting 20psi on his GT3071, you are NOT making more power than your friend. xxPSI is an arbitrary number that tells you nothing without knowing what turbo it applies to. DO NOT embarrass yourself and possibly the Saab community by walking up to someone at a car show not knowing anything about the car, and ask, "How much psi is it doing?"
You would be disowned, if I were your mother.
Now the Stages
This hierarchy of staged tuning has have been common nomenclature for years now so we stick to them. Horsepower ratings are approximate and will vary by dyno, your Saab's heatlh, your specific modifications, etc. Even though this part of our forum is for all NG900 and OG9-3's, these mostly pertain to those without the TD04 but do not differ by much really, besides the turbo.
Stage 1
~220bhp/190whp
'Stage 1' ECU tune
It's as simple as that - your ECU gets remapped making appropriate ignition timing and fueling adjustments.
Open air intakes, aftermarket air filters are OK but one member has proven there to be no gain over the stock filters. If you want those things for the look/noise, that is fine.
Stage 2
~240bhp/210whp
'Stage 2' ECU tune, 2.5" catback exhaust
Not much to explain here. You have a larger exhaust for the turbo to breathe out of (imagine blowing through a straw as hard as you can) and it flows freer, allowing the turbo to spin easier.
Stage 3
~260-270bhp/230-240whp
'Stage 3' ECU tune, 3" turboback exhaust OR 3" downpipe mated to 2.5" exhaust, upgraded intercooler, stage 2 clutch disc and Viggen pressure plate (optional)
Instead of just a larger exhaust from the catalytic converter and back, ideally you're replacing the whole system from the turbo on back to the muffler with a 3" system. This further loosens up the back pressure created by the smallish 2.25" stock system right at the turbo allowing it to spool slightly faster but more importantly lower Exhaust Gas Temperature (EGT). Genuine Saab offers a very fairly priced full 3" turboback system for a similar price that many would want for just the downpipe, which is why it gets my personal recommendation. Mine has held up just fine for over 5 years. You can also make your own downpipe and exhaust for very cheap. If you have a nice cutter, a few well-chosen 3" bends, and a welder (or a friend with a welder) you can spend less than $100 for a nice downpipe.
As for the intercooler, many people like to upgrade to the 'Viggen intercooler' which can be found on either the B204R or the B235R. Due to the high cost of one, though, I would highly recommend either searching for one on eBay or if you have the money, purchasing the ETS intercooler which is more drop-in. For those of you who are looking on eBay, 28x8x3.5" are the dimensions of the absolute largest intercooler you can use including the end tanks. An intercooler is not necessarily required at this level BUT if you are using the stock NG900 unit, heat soak will be very noticeable and you probably won't be able to go more than 2 gears worth of WOT pulls before you feel the power fade. Also, a cooler charge temperature means you are much less susceptible to knock which is good enough reason. A Viggen intercooler is slightly better than the NG900 one but not by too much.
Your original clutch may also start to slip at this point depending on how its been treated so if it does, now is the time to upgrade. The stage 2 Clutchnet disc offered by GS is great for daily use and very similar to the stock feel. Stage 3 is a little more aggressive but not impossible to deal with. I had a stage 3 disc last for about 60k miles which included 30+ pulls on the drag strip and COUNTLESS runs while tuning. I'm now using a stage 2, as recommended to me.
Stage 4
~285-295bhp/250-260whp
3" turboback exhaust, upgraded intercooler, TD04-15T 5cm^2 or 6cm^2 housing.
The difference between stage 3 and 4 is the turbo. If the Mitsubishi is the turbo you already have on your car, then this is where the hierarchy merges. The TD04 is just slightly bigger than the T25 but even so, you will need a retune if you are coming from stages 1-3 because your new turbo will be flowing slightly more air.
From this point on, the stages are slightly less defined due to the number of different paths you can take. They refer more to the power level than the actual hardware but because we don't want to remember 20 different stages, I will group them as best as I can based on this. It is not necessary to stick to them, though. I also won't drag out too much detail at this point because if you're at this level you probably need to be doing a little more research for info that my little thread won't give you.
You should also consider a custom, in-person tune as a requirement beyond this point.
Stage 5
325-395bhp/285-350whp
3" turboback exhaust, upgraded intercooler, 3 bar MAP sensor, Custom tune, T28 OR GT28rs (Disco Potato) OR GT2871 OR TD04-18T OR TD04-19T, Walbro 255lph fuel pump, Siemens 60# or 80# injectors, Pistons (T7 cars required)
For those looking for a lot more pep in their step, this is where things get fun. I have seen all kinds of power numbers with the T28. The TD04-18T - in my opinion, you're better off just getting the 19T because the difference in lag between the two is negligible. With the 19T, a personal friend of mine has made 320whp. The GT2871 probably surpasses them all in terms of power - I believe Nick at GS made closer to 400whp with one.
For those of you with T7 motors: your engines will not hold up much past 300whp. It may for awhile but you are eventually doomed. If you want to reach this level and beyond, it is necessary to build the motor.
For fueling, I put the Walbro because it's cheap enough of an investment (~$100) and if you want E85, you're gonna need it anyway. The Siemens injectors are available in 60lbs/hr or 80lbs/hr. Again, my personal recommendation is to just get the 80lbs/hr ones because the price difference is so small and because you don't want to 'under-injector' yourself if you decide in the future to make some changes.
A 3 bar MAP is only required if you expect that you will be boosting more than what the stock 2.5bar MAP sensor can read. 1 bar is 14.7psi. Accounting for 1 bar of atmospheric pressure, a 2.5bar MAP sensor can thus read 1.5bar of boost which is 22psi. If you are going to be above this, upgrade your MAP sensor.
Stage X
400bhp-700bhp and beyond.
3"/3.5" turboback exhaust, upgraded intercooler, sufficient fueling, pistons, rods, larger camshafts, valvesprings, larger turbo, tubular manifold, external wastegate, etc.
I think you get the idea by this point. There's always more you can do. Enem camshafts for better intake and exhaust of gases from the combustion chamber in along with uprated valvesprings allows the motor to breathe better and be better suited for whatever large turbo you decide to stick on it. Holset HX35, Holset WH1C, Garrett GT3071, GTX3071, GT3076, GTX3076, and the Holset Super 40 are all tried and true for our motors. [B]600whp[B] is a number to remember - a stock B204L motor has been proven capable of holding up to this amount of abuse when tuned correctly. Many of you will not reach this point but the upside to that is most of you can go without 'building' your motor unless so desired.
The nice thing about the Garrett ballbearing turbochargers is that they are available with a T25 flange, thus will bolt up to your original manifold. The downside is the higher cost. However there is a Garrett to fit whatever your horsepower needs are so research them and find the one that is right for you. Dyno charts are floating around everywhere.
The Holset turbos are much cheaper but for the NG900/OG9-3 you must purchase or have made some sort of tubular manifold with a matching flange (divided T3 or T4 depending on your selection). A known version of the Holset HX35 comes from 94-02 (or around there) Dodge Ram Turbodiesel Cummins engine. Very cheap to find on diesel forums and will make close to 500whp on E85, quick spooling when matched to a twinscroll manifold. The Holset Super 40 is a high performance Holset that has made over 600whp for some people. You don't need my advice if you're at that point.
The tuning
For the tune, there is no tune that will just work for any range of turbos. In other words, get a custom tune once you go beyond stage 3 or 4.. Each turbo has different spooling characteristics thus different fueling needs at different rpm at different pressure ratios. Thus, you are better off allowing someone with experience tune your car in person using proper instrumentation. It is worth it for safety's sake and so that you can get the most out of your setup. If you're up to the task, you may also join ECUproject where you can learn how to tune your own ECU. Much easier said than done but it is not rocket science. T5Suite for T5 ECUs, T7Suite for T7 ECUs. No, you cannot swap a T7 ECU with a T5 one.
My personal recommendation for tuning from being on these forums for a few years now and after learning T5Suite myself? Anyone who can make power gradually without just spiking the torque ASAP, who does not blows up engines, and who knows what they're doing. Base your decision on facts, data and experience. Just because a customer is happy that their car is faster does not necessarily mean the tune is a good one so do some research before choosing. It's very easy to max out on torque and roast the front tires in 5th gear but what good does that do for acceleration? None.
Feel free to contact me via PM for more specifics.
More on large turbochargers - are they right for you?
The issue (notice I didn't say problem or disadvantage) of a larger turbo is the aforementioned lag associated with them. However once it is spooled, it will reach and maintain a higher flow rate over a larger registry (rpm range). But in stock form, the B204/B234 engines can only rev so high - somewhere in the neighborhood of 7000rpm - so you may get cut off before your turbo is done making power. Stock camshafts are also a bottleneck as they are not meant to breathe in the upper rev range and begin to choke in those bounds. The way to overcome these things is to upgrade valvesprings and camshafts so that you can take advantage of where the turbocharger flows most efficiently. Revving to 8500rpm and beyond is not unheard of at this point and you are thus only limited to the turbo you decide to use.
"But turbo lag! I've watched YouTube videos and my friend's car doesn't spool til 4k! That isn't practical!"
This is a common misconception, in my opinion. I have daily driven my car with for 3 years now with a turbo that reaches has the potential to reach full boost at around 4100rpm. One thing you notice when you go up in size is that the gas pedal is no longer an annoying On/Off switch of torque. In other words, it's really nice for commuting around town. In everyday driving, 80% of the time you won't be driving at wide open throttle so a high amount of torque isn't really necessary in the everyday rpm range. But if you get an itch and want to go fast, it's as simple as a downshift away. For those of you who race regularly, lag in first gear is the only lag you will have to overcome given you are shifting properly.
As an added bonus, better gas mileage is more easily attained and you may also find yourself just enjoying the drive for once rather than feeling on-edge just as the peaky stock turbo would.
T7 Boost Pressure Control Valve (BPC) for T5 cars
This is an upgrade that I highly recommend for those with T5 cars who either already have a faulty boost controller that needs to be replaced or who want more reliable control. The newer one is a much better design and if it does happen to go out, they can be had for a low cost. They are extremely cheap especially when compared to the T5 unit and only require some easy rewiring to the harness and literally an adjustment to two different numbers within T5suite. This is by no means required at any level but it's just nice to not worry about the crappy stock one. Search the forum for the How-To's.
Suspension
Do NOT forget your suspension modifications. Believe me when I say much over 400lb.ft. of torque is USELESS on the road if the chassis is not up to the task of holding the tires on the ground. I'm not covering suspension much in this thread but do some research on your own and don't neglect it. Going much over 100mph in these cars on stock suspension is pretty scary. Let alone 150mph (on a track, of course).
Other nice things to have
There's always more you can buy. Nothing is set in stone.
Silicone vacuum lines - much more durable than rubber ones, go to your favorite vendor and order enough to replace all of them
Boost gauge - All of these cars come with a factory 'gauge' on the cluster but it's more fun to watch than anything. There are lots of good brands, be sure to find one that reads up to 30psi just in case
Methanol Injection - Spray a methanol solution into your charge pipes, cool the charge temps to make more power and run more safely. There are many DIY guides online, Snow Performance sells kits, too
Uprated engine/transmission mounts - To my knowledge Genuine Saab is the only place that makes one for us. Very worthwhile, keep everything in place once you start beating on the car
LSD - Traction and drive is greatly improved. Pricey and should be done by specialists only
Tires - If you're really into stoplight showdowns, a good set of tires are a must. More sticky tires will also wear faster because they are softer - a treadwear rating between 100 and 200 will be noticeably stickier than a treadwear rating of 400 but they will also last 1/4 and 1/2 as long, respectively.
E85 - Use ONLY if you are tuned for it or if you have a separate ECU that is tuned for it for your car. With larger turbochargers, you can expect to gain at least 40whp-50whp. I'm not sure what the potential is for stages 1-3, but there almost certainly are some
Most of all, be safe. And be sure to change your oil at regular intervals!
-Branden
New to tuning Saab's? Start here
-Branden
Old 18-07-12
comtrang's Avatar
Garage
Saving this post for dynos
-Branden
Old 18-07-12
comtrang's Avatar
Garage
This post for a list of vendors/brands
-Branden
Old 18-07-12
comtrang's Avatar
Garage
And this post for anything else I may need to add
-Branden
Old 18-07-12
Shirozina Shirozina is offline
My Saabs: 2002 9-3 aero 5spd 3dr
Good work and should be the 'go-to' post for beginers but maybe it needs a bit of 'shaping' from a consensual pooling of knowledge and experience? i.e I would disagree that stage 3 'needs' a full 3 " exhaust and clutch upgrade - it only 'needs' the 3" DP to avoid excessive EGT's and if your stock clutch is in good condition it will hold OK for the kind of torque a T25/ GT17 will deliver. Full 3" exhaust, clutch upgrade, IC upgrade are all nice add ons but not essential. If you have a 9-3 it's going to be an old car so it's important for people to be able to decide what's essesntial and what's icing on the cake. I'd also say suspension and brake overhauls are essential components for stage 1 and 2 and for stage 3 upgrades in this department are mandatory before you start adding 3" cat backs, IC's, clutches etc.
2002 9-3 Aero 3dr 5spd
Old 18-07-12
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5
Garage
Nice work comtrang,
This place needed one of these.
B.L.T.H.....Brake late Turn hard
Old 18-07-12
griffin dai's Avatar
griffin dai griffin dai is offline
My Saabs: 9-3 2.8 v6 Aero
Good write up, some nice & helpful info there for a lot of guys
...but you've missed out the gt28rs....so go & re-type it all out 10 times
Old 18-07-12
comtrang's Avatar
Garage
Thanks will edit. Sorry I was making it as I was neglecting studying for Linear Algebra for hours so it was a bit rushed I knew I was leaving out some factors.
Suspension and brakes - because of the route I went with my own car probably explains my bias for lack of those I'll edit the original with those things when I get a chance.
-Branden
Old 18-07-12
comtrang's Avatar
Garage
DOH! Will add this, too. Let me know if I left out anything else, I really was fried by the end of it. I almost forgot to even mention the blow off valve, lol.
Originally Posted by bogan View Post
Nice work comtrang,
I hope it helps people. It's not that I get annoyed with all the new people or anything because I definitely remember when I was at that point. It's just nice to consolidate everything and I knew it would take a couple hours to put together if someone were to do it.
-Branden
Old 18-07-12
TwinCam TwinCam is offline
My Saabs: '99 9-3
Don't forget the '99 9-3 came in a HOT option. (B204R)
Bumped the power up to 200 with the same T25 (different intercooler)
Old 18-07-12
comtrang's Avatar
Garage
Thank you! Added!
-Branden
Old 18-07-12
bogan's Avatar
Garage
I vote for a sticky.
There is a sticky thread up there that hasn't had a hit since 2010. Get rid of that one
Old 18-07-12
Another useful way of looking at upgrades is not simply to say what you need but the underlying reasons why it's needed and thus avoiding further questions. Thus the upgrade path is staged by what is the component or components that are resticting more power and may go something like this;
Stock - ECU limits are resticting power - stage 1 and 2 ( or MBC for T5) alow this limit to be raised to limit of stock hardware.
Stage 1/2 - Stock DP restricts power as EGT rises to dangerous ( valve and piston melting) levels - 3" DP allows more power without dangerous EGT's
Stage3 - turbo output limits power particularly in the upper RPM range - upgrade turbo
Stage4 - fueling and turbo ( and pistons with B2x5 engines) limit power - upgrade these + good idea to look at upgrading IC, CAT back and clutch
ETC ETC
Old 18-07-12
Fox Fader's Avatar
Fox Fader Fox Fader is offline
My Saabs: '98 900SE Manual
Perfect, now I can come right to this when I'm trying to remember in which direction I'm going.
Old 18-07-12
seabench seabench is offline
My Saabs: '02 93 Anniversary edition (2.0t)
Brilliant!
I don't think it was all markets had it, but there's another T7 engine:
B205E - 150bhp (t17), I believe this is on 2000-2002 Saab 9-3 Base
Old 18-07-12
Also B204E - 155bhp - T25 tubo / T5 without BPC control and with the B205E commonly reffered to as the LPT or low pressure turbo. Former needs BPC valve and software and latter just software to attain FTP ( 185bhp) status.
Old 18-07-12
rabbit's Avatar
rabbit rabbit is offline
My Saabs: 2002 Vig BCB Stg2+
Great guide for beginners! I also vote for sticky!
My Vig >> 345ftlbs 300hp <<
BrewCityBoost
CaseyR@BrewCityBoost.com
Brew City Boost on Facebook
Old 18-07-12
comtrang's Avatar
Garage
Everything added, thanks for that info! I knew that there existed some LPT models but wasn't sure off the top of my head the specs and was a bit lazy.
I have not added something like this in yet but I will get around to it when I have more time today perhaps I appreciate all your feedback. This thread isn't some special magic creation I've done, I'm just trying to make a nice collective that everyone can unbiasedly and contribute known facts to.
-Branden
Old 18-07-12
Tap804's Avatar
Tap804 Tap804 is offline
My Saabs: Stg 4 900 SE vert
Garage
Might want to throw some stuff in here about the N/A stuff as well, though turbo is king in our cars. just for future reference.
Old 20-07-12
bogan's Avatar
Garage
The first mod a N/A car should have is a Turbo
Similar Threads
BSR - Read PPC Molitoth Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning 9 28-05-09 09:19 AM
A must read,This is probably the funniest post I have ever read! davidlytle Classic Saab 900 Workshop 4 20-11-07 05:20 PM
power steering pump *CAUTION PLEASE READ* saab90089 Classic Saab 900 Workshop 0 04-08-05 10:58 PM
please read boxman Saab 9000 Workshop 0 07-02-05 07:27 AM
please read boxman Saab 9000 Performance, Mods & Tuning 0 07-02-05 07:25 AM
