Changing the oxygen sensors - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 2nd July 2012
kerbyjonsonjr kerbyjonsonjr is offline
My Saabs: 1996 Saab 9000 CS
Default Changing the oxygen sensors
I have a 1996 9000 CS and from time to time my check engine light will come on and I got the code checked out and it says it's the oxygen sensor. I have also been getting about 6 or 7 miles per gallon less than I normally do so I think it's time I change them.
Is there anyway to tell whether it is the oxygen sensor that is before or after the catalytic converter or is it best to just change both of them? Does anybody have any experience with the universal ones that require splicing or is it worth the extra money to just get the ones that fit and plug right in? I've had good experience with http://www.thesaabsite.com/9000/9000fuelsystem.htm so I was just thinking of buying from them. It would cost me about $130 for both sensors from that site so it's not tooooo bad.
Also, is there any trick to getting these suckers out? I tried getting the one that is before the catalytic converter out and I couldn't even get the thing to budge. And lastly, is there an easier way to get at the place where the wires plug in or is reaching around and just feeling for it the best way? Thanks for any help!
Old 2nd July 2012
Jim Mesthene's Avatar
Jim Mesthene Jim Mesthene is offline
Saabista
My Saabs: Wife's 9-3
Generic substitutes are fine.
Swapping parts based on stored codes may not prove to be cost effective.
In your guts, you know he's nuts.
Old 2nd July 2012
Twinsen Twinsen is offline
My Saabs: 9000
If your fuel economy has dropped suddenly, it's the upstream sensor, though the code should tell you which sensor. If the heater impedance of the generic sensor is much different from stock, the ECU will throw a code. It's happy at around 8 ohms.
Like you've discovered, the sensor in the cat is a headache. It's best left alone unless you know for sure that it has failed.
Old 5th July 2012
Shan's Avatar
Shan Shan is offline
My Saabs: 9000, c900, 96 V4 & stroker
When my MAP sensor started to fail, the oxygen sensor code popped up intermittently. A week later, the MAP sensor died completely and the MAP sensor code appeared.
Old 5th July 2012
jw.roberts jw.roberts is offline
My Saabs: 97 9000 cse turbo
if you know anyone with a scanner/code reader that will show live data watch each O2 sensor make sure the voltage is flipping above and below .5 as far as the sensor itself generic is fine. O2s are universal your paying for the wires and connector being ready to plug in. get a can of PBblaster soak em and let em sit for a while. if still can't break it loose try tightening a little then try to break it loose again just ve careful not to round it off. good luck and watch ur knuckles
Old 6th July 2012
KevinC's Avatar
KevinC KevinC is offline
My Saabs: sorted 9K Aero 1993, 9000R, 454 GMC
If you do need to change them, my experience: penetrating oil and special sockets do not work on the tough to get out ones, 2,000F torch does work.
Old 28th August 2012
c900's Avatar
c900 c900 is offline
My Saabs: 81 8V 900T, 91 2.1 900i, 90 9k 2.0 Carly
When the o2 sensor is working, it should output a varying DC voltage swinging between about 0.4 and 1.0 volts. Tracking down a replacement atm since I now have two cars that could need one (my 2.1 900 as well), and I'm hunting for a genuine Bosch or OEM Saab one.
Craig.
Craig Dewick - Somewhere in Oz -
Flux Capacitor Engineer at Mr Fusion - 1981 8V 900T, 1990 9k 2.0 Carlsson, 1992 2.1 900i - RIP Moose.Parts
Tags
9000 cs, check engine, oxygen sensor
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Oxygen Sensors Lecky NG900 & OG9-3 Workshop 6 6th September 2010 07:07 PM
Testing oxygen sensors ologist NG900 & OG9-3 Workshop 5 9th July 2010 12:14 PM
How often should oxygen sensors be replaced? saabfire 9-5 Workshop 8 1st March 2010 05:09 PM
Cheap oxygen sensors! ProfZ C900 Workshop 1 1st April 2005 02:08 AM
oxygen sensors Sparxhawk 9000 Workshop 1 22nd January 2004 03:24 AM
