"jerky" driving at high-rpms - SaabCentral Forums
Old 25th June 2012
SilverStone641 SilverStone641 is offline
My Saabs: 2005 Saab 9-3 2.0t
Default "jerky" driving at high-rpms
This just started in the last few days, bear with me as i describe it poorly.
Whenever i put the accelerator to the floor, the car takes off like normal, until it hits higher RPMs, (usually 2k-3k) and "jerks" or lunges. Almost like it's not getting enough air or fuel. Another interesting piece is this morning, from a cold start, when i romped on it, it drove like normal. RPMs went up, turbo fired and i took off like i'm used to. It was only after driving the car for 15-20 minutes that the lunging/jerkiness started occurring. As long as i drive conservatively and accelerate slowly and smoothly, this doesn't happen.
It reminds me a WHOLE lot of when my throttle body failed on my 02 9-3.
Has anyone experience anything like this and could point me in the right direction?
Old 26th June 2012
New symptom. Now i have next to no power in first and second gears. It feels slightly faster than letting the car idle forward. The car picks up almost immediately after that. It feels a lot like limp home, without the warnings. I'm thinking my transmission is failing again.
Old 26th June 2012
nickmatt nickmatt is offline
My Saabs: saab 9-3 aero
mine is doing exactly the same, i have read somewhere that it could be the coil pack
i am also interested to see what the replies are to this
Old 26th June 2012
I've been doing some googling, as my car is getting worse, and found these:
http://www.saabscene.com/forum/threa...wer-at-low-rpm
http://www.saabcentral.com/forums/sh...d.php?t=230900
Sounds like it could be any number of things.
New symptoms: I fired up the car for the commute to work this morning and the thing ran great. The throttle was light and extremely responsive. I stopped at Autozone to see about a replacement brake boost check valve. Once i got back into the car and started it, the motor started revving slightly then dropping below idle repeatedly. I took a few laps around the parking lot and it seemed to clear up. However, during the latter half of the drive to work, the throttle started to feel heavier and sluggish. Not sure if these are related or even helpful, just trying to keep notes on what the heck is going on.
Old 26th June 2012
thanks for the info, mine gets jumpy when i floor it then the engine light comes on and there it seems like its only working on a cyliner or 2. i switch it off and back on again and everythings fine
i am afraid to take it to the diagnostics in case i get a fright at the bill
Old 26th June 2012
BKLYNHOLLA's Avatar
BKLYNHOLLA BKLYNHOLLA is offline
My Saabs: 04 AERO
Do the following:
Get a bottle of "sea foam" and do throttle body cleaning w/fuel treatment and check air filter.
Replace your spark plugs.
Verify ignition coils are ok.
Check transmission fluid (drain & refill if ness.)
Old 26th June 2012
Originally Posted by BKLYNHOLLA View Post
Do the following:
Fantastic! Now i have somewhere to start. Thank you! I'll report back on my results.
Old 1st July 2012
i have just had a really cheap fix !
i have been using a large ammount of water for some months now, and tbh i just put it down to the extreme high temp of the engine and its compartment (2.8 v6)
but 2 days ago i had a 'dump' of water from the engine, so i decided to put some k seal (whole water sealant) in
and low and behold it seems to have done the trick ! it is driving smoothly again,and there is no jerking
i am amazed, and fingers crossed it has saved me a very expensive repair
hope this may help somebody else too
Old 2nd July 2012
sleeper900 sleeper900 is offline
My Saabs: 07 Saab 9-3 Aero 2.8T
Large amount of water? Like burning coolant?
Old 2nd July 2012
smurkenstein's Avatar
smurkenstein smurkenstein is offline
My Saabs: 03 9-3 Aero
If you car is a 2005 and has not had the spark plugs changed, there a good chance you have a dodgy plug. I had the same symptoms a while back. The juddering only happens under heavy load and mostly in the high gears. The plugs are a service item at about 70000 mi.
Old 2nd July 2012
it was, yes
Old 2nd July 2012
smut smut is offline
My Saabs: 99 93 stg.3
Default Re
Sounds like a headgasket leaking but I wouldnt count on the repair working for long.Good luck though.
Old 2nd July 2012
oh dear !
thanks for the info anyway
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Intermittent engine surging/"hunts" while driving or in park. Only when warm 3Saabs 9-5 Workshop 1 2nd July 2011 02:51 AM
Driving with the "Check Engine" Light... schmearvin 9-5 Workshop 5 27th April 2011 05:10 PM
Saab Aero Academy makes Forbes top 10 "cool driving schools" lexington01 The Lounge 2 15th November 2008 07:57 AM
Driving like "winter" mode selected fourstar787 9-5 Workshop 13 8th July 2007 01:43 PM
2.3 Turbo stalling while driving "cutting out" HEL malamutt28 9000 Workshop 16 21st October 2004 10:21 AM
