| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
Can anyone confirm is this means the timing belt snapped on my car and or the valves/head/pistons are smoked...
A prompt reply would be greatly apprecaited. I really need to find out what this issue is, because if its the timing belt, could it have slipped off the teeth? Or just completely snapped? I thought they were like a REAL chain, never heard of one of those just snapping like that. |
| Sponsored Links | ||
Advertisement | ||
I posted this video in one of your earlier posts about your v6's start up problem. Saab/GM's 54 degree V6 is an interference engine, meaning there is almost zero tolerance toward timing slippage. As I suspected earlier, there is a slight chance that broken serpentine belt could be sucked into the timing area via seized water pump and that can cause a lot of damage if timing is correspondingly affected.
If your car sounds like the one in the video, I think damage has already been done to valve/piston etc. I would stop cranking car right now and take the timing cover off to see the condition there before taking everything off to check out the heads. |
Do you have fuel pressure? Can you hear the FP when you turn the ignition to on? Did you check your fuses, relays, and ground connections?
PEOPLE WHO TEST DRIVE A SAAB USUALLY BUY ONE Saab Owner/Driver since 1985, |
I checked everything and have not gotten it to turn over. It happened on the highway. I heard a loud snap and then this happened. Im assuming the timing belt snapped :/
I took off the serp belt and tensioner pulley engine mounts AGAIN took out the screws for the timing belt cover, got most of it off gotta get off the pulley for the idler in the middle and then its completely removed. The belt doesnt seem to be snapped or even off a tooth, there is complete tension there.... But my alternator pulley seems kind of bound up. Would a dead alternator prevent my car from running and turning over? Im assuming that would most definetally be the cause of my dead battery. Im sorry for the million questions. IM just a DIY single dad mechanic. Trying to get my car back on the road with the limited resources avaiable (fiances). I hope to find out that a bad alternator would be the cause of all of my problems... Is there any way it is possibly the AC compressor or the water pump?
Well, take the alt belt off and see
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Found a 14.1 1/4 mile video of a 9-3 Aero | Wagon | Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning | 6 | 24-08-11 01:47 PM |
| 04 SAAB 9-3 Wont Start (Video Included) | utc18 | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 9 | 04-12-10 02:53 PM |
| Found this sweet video: Saab Arctic Adventures | jspz3 | The Lounge | 1 | 29-04-10 11:47 PM |
| SAAB 9-3 Finger Start (VIDEO) | mickel1138 | The Lounge | 3 | 31-08-09 09:22 PM |
| googled saab skida-but found a 9-3 racing video | saab9x | The Lounge | 7 | 28-07-05 12:41 PM |
