| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
My first ? Is... What color is the signal wire to the starter?
I get no codes and no warnings. All fuses are good As well. There is a possibility the alternator signal wire and the starter wire got switched. Starter is yellow right? |
| Sponsored Links | ||
Advertisement | ||
starter signal wire is yellow.
check power at the yellow wire with a volt meter while cranking |
I'll bring my meter and long leads home today.
So where I stand now... The main power cable has power but the signal wire doesn't get anything when I turn the key. Would the car be immobilized?
check any message display on the SID, check twice unit, check that little immobilizer antenna around the ignition lock. check neutral safety switch
Good to go!!! It was the shift linkage. I gat bent down a little bit ant the it was stuck just between park and reverse. I bent it back up, cycled threw the gears and fired right up!! Thank you guys. It's nice to be able to bounce ideas around.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2004 Saab 9-3 won't turn over, battery voltage good, won't run jumping starter relay. | saleenmav | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 4 | 12-06-12 04:10 PM |
| about 10 turn of the starter motor to get it going!! | davefoxcars | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 1 | 23-07-11 09:24 AM |
| Turn Signals, stereo and windows stop working sometimes + dead starter | selebrin | Saab 9-3 & NG900 Workshop | 4 | 02-07-10 02:35 AM |
| HELP, Starter engages the moment I turn to unlock,!!! | onfire | Saab 9-3 & NG900 Workshop | 5 | 22-12-03 05:17 AM |
| No start. Starter motor fails to turn. | nicwik | Classic Saab 900 Workshop | 4 | 07-09-02 11:35 PM |
