| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
I love this car but can honestly say it has been nothing but a headache. From the CPS, to the window roller breaking, to the serp belt and tensioner pulley. I have no clue what to do with this car, it wont start I dont have money to get it towed to a garage and looked at. Is there any chance that I could have burned out a fuse for one the relays? I heard there was a starter relay NSS thing that happens to these cars and prevents them from starting.
| Sponsored Links | ||
Advertisement | ||
ok try to give us more info, does it crank? do you have a check engine light? if the car does not attempt to crank check the nuetral safety switch. if its cranking but no start, check the fuel pump, check the valve on the fuel rail. if you are getting it to crank but there is no spark then thats a whole differant story.
its cranking, no CEL is on. I just bought a brand new battery. nthing is siezed up all pulleys/wheels are moving when I turn the car over.
When I go to start it, I feel like it almost sounds like its short circuting... I can hear the fuel pump filling up, just dont got a clue about what the NSS is.
Ok Cranking equals turning over. It means the starter is turning the engine.
This eliminates the starter. (as long as it is turning when trying to start) the NSS is the neutral safety switch. It is on top of the trans where the shift cable goes to. It will only let the car start in neutral or park. If it is turning over NSS is ok Did you check fuel at the fuel rail on top of engine? It has a little cap similar to the tire fill valve but bigger. Remove the cap. (it finger tight) If you press the little thing in the middle (as if you were letting air out of tire) it should spray some gas. Be careful and protect your eyes. If not fuel is not getting to the rail at enough pressure or n one at all. The DI Cassettes should throw a code.
'01 9-5 Wagon 2.3. '00 9-5 Wagon 3.0, 1999 9-3 Conv. 1990 900 3 dr RIP, 1985 900 2 dr coupe RIP 1986 900 4 dr RIP 1976 99 2 dr RIP, 1977 99 5 dr RIP 1973 Sonett Gone but not forgotten |
what sounds? a little more detail.
Its like a electrical short I cant really mimic the sound, it sounds like electricity is sparking almost?
Just took off the cap and pressed on it. Gas came spraying out, checked it twice to make sure it wasnt left over gas. both times gas came out. My car is cranking over its just not starting.
I think you need to track down that sound get as close to it as you can, if it is sparking that is bad. might be a relay tripping back and forth? You might want to pull your spark plugs and check them at this point. But track down that sound I think it may be important. Check all connections that you can see around the engine. make sure the DICs (Direct Ignition Cassettes) wires are plugged in and tight.
the sound is coming from the relays under the instrument compartment under the dashboard. and the dics are all plugged in and such. Maybe Ill check the plugs.
could be the relays themselves gone bad :/ not cheap fix if it is, at least I never found them cheap
next before before you continue i would connect a scanner to it, and see if all the components are comunicating. there is relay box 22B i think they call it, its under the drivers area, you need to remove the bottom panel and 1 other screw to drop the relays.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| banjo bolt on water pump leaking | duramax2002 | Saab 9-5 Workshop | 5 | 01-03-12 08:20 AM |
| Oil coolant galley is leaking coolant, how to fix? | zende | Saab 9-3 & NG900 Workshop | 5 | 10-11-11 03:49 PM |
| Coolant leaking | DJamesUofM | Saab 9-5 Workshop | 7 | 24-09-11 06:10 PM |
| Coolant leaking | ting | Classic Saab 900 Workshop | 6 | 17-05-09 09:10 PM |
| AC Compressor Removal (Bolt Sizes)(Maybe leaking issues too) | DrSquirley | Classic Saab 900 Workshop | 4 | 24-03-05 03:17 PM |
