New guy, possible '85 900 purchase, needs slave cyl - SaabCentral Forums
Old 13-06-12
mrdane mrdane is offline
New Member
My Saabs: none yet
Default New guy, possible '85 900 purchase, needs slave cyl
The car is about an hour away. Seller says the slave cylinder is bad because he used the wrong hydraulic fluid and he doesn't want to do the job because a special tool is required.
Is this possible the wrong brake/clutch fluid can ruin the seals? (Edit: apparently the hydraulic system was converted to use synthetic only?)
Is a special tool required for the job?
Car is a non-turbo, base model 8 valve and has 220k on it with no A/C. Kinda just basic transportation but in nice shape.
Old 13-06-12
Jim Mesthene Jim Mesthene is offline
It's a strange story, but some fool may have switched to DOT 5 silicone fluid. If it later got mixed with standard fluid disaster could be looming. The whole story sounds a little fishy, so it better be really cheap. Keep in mind that the brakes and clutch share a reservoir; contamination in one is contamination in both systems.
There are a hundred threads here about how to replace the clutch with or without Special Tools.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 14-06-12
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
If done properly, DOT 5 fluid is fine. But to do it properly invloves changing every rubber component in the whole system , flushing the metal pipes and flusing the calipers, master cylinders, slave cylinder.
I've been running silicone for years in mine, and my Dad has been running silicone for decades in his with no bad symptoms.
Do it wrong, and you can get into a mess
Photo Gallery
Old 14-06-12
New Member
My Saabs: none yet
Define cheap. What kinda dollars are you talking?
So running non-synthetic after conversion to a synthetic system can cause seal failure?
Some images.
another
another
Old 14-06-12
white65's Avatar
white65 white65 is offline
My Saabs: SPGCLONE
Real cheap, it's a high mileage '85 with slave issues and a case of bad engine wire harnesses in that year.
It's clean looking though.
Old 15-06-12
New Member
My Saabs: none yet
Asking price is $850.
Old 15-06-12
nutcase's Avatar
*apparently* you can mix it with regular fluid, but then the whole point of it its gone, and to get it back you'd have to strip and re-seal it all again.
Photo Gallery
Old 15-06-12
jamengual's Avatar
jamengual jamengual is offline
My Saabs: 89T,87 SPG,93 900S,91 4d, 97 9K Aero
Sorry but $850 for a four door 85 that must have rust somewhere and "slave" problem no way.
Just to give you an idea :
1990 Rusted 900s for $350 ( engine in good condition and manual transmission in ok condition, body is gone)
1991 Four door Auto No rust at all, bad AAM ( only that) , original stereo etc (now is my parts ca) really good condition it cost me $350 in Canada.
I'm not bragging here but I think that is way to high and that you can find a 900s in good condition for better price and two door.
Old 15-06-12
scantar's Avatar
scantar scantar is offline
My Saabs: 1992 vert turbo, 1984 3 door turbo
Obviously geographic areas are going to play heavily in what is a "decent price" and what is a "no way"
That 85 looks super clean, high mileage or not, and for $850 (or $700 if you can get it for that) around here that wouldn't last an hour if all it needed was the slave replaced.
Just anudda way to look at it...
Originally Posted by bimmerjeeper View Post
So what you're saying is that I need to find a way to make my rod longer?
1992 Turbo 'vert, 1984 Turbo 3 door
Old 15-06-12
jamengual's Avatar
Maybe I should ask where is the car ?
if is in the States then I think that is too expensive, Vancouver BC has been always much expensive on that front.
I think that sometimes people rush to opportunities that sometimes are not the best like I did with my SPG and sadly I have to say that if I have the chance of doing it again I will not do it. Is better to wait for a better opportunity I think.
4 doors cars have bad resale in my opinion.
If the car is in UK or somewhere else, I can't speak on that.
Old 15-06-12
New Member
My Saabs: none yet
It's in Florida. Originally a Texas car. No rust (seller says.)
Old 15-06-12
jamengual's Avatar
Thumbs up
Then wait for a 900S at least, you will find one with time.
Old 15-06-12
scantar's Avatar
For that price, I'd be all over it. Rust free with that interior? If everything else is sound (besides the reported slave cylinder) I'd take a hard run at it. Here you can't find a piece o'carp for that price and I'm only familiar with my region of the planet...but it's hard to find one in any condition at that price here. Have to be real lucky to get one under $1500 that doesn't need a lot of work.
Similar Threads
It's the slave, what to buy and where pls... keywestgurlie Classic Saab 900 Workshop 72 03-11-11 09:56 AM
Bad Slave SOAB Classic Saab 900 Workshop 5 07-04-11 07:57 PM
slave cylinder as well? paolo Saab 9-5 Workshop 2 22-06-07 05:14 PM
more slave cyl help please jbvw96 Classic Saab 900 Workshop 4 22-08-04 06:25 PM
slave cyl. help !?!?! jbvw96 Classic Saab 900 Workshop 5 21-08-04 11:26 AM
