Low Coolant warning but tank full - SaabCentral Forums
Old 13th June 2012
SwedishLoyalty's Avatar
SwedishLoyalty SwedishLoyalty is offline
My Saabs: 2000 9-3 SE
Garage
Default Low Coolant warning but tank full
I'm getting the message that coolant is low but the level is good when I check the tank. Is this due to the coolant sensor malfunctioning? Do I need to replace the whole expansion tank to correct this problem, or is the coolant sensor a separate assembly?
My 97' 900 SE had this very same problem and I never bothered with it.
Old 13th June 2012
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
I'd check the connections on the sensor plug, give it a jiggle and re-start the car.
signature here.
Old 13th June 2012
Garage
Okay. If that's fine then what?
Old 13th June 2012
BobSaabit's Avatar
BobSaabit BobSaabit is online now
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9 'vert
You probably need to clean the sensor. Take the tank out and use various implements to clean the sensor float and the area around it. You'll probably want to clean inside the tank too using various creative tools once you see how much scum has accumulated in the hidden compartments.
Re-install. If that doesn't do it, you need a new reed switch. That's that part that the connector hooks on to. You can't buy it separately, you have to buy the whole tank...so a junkyard is usually the best source for a replacement.
Old 13th June 2012
Garage
Thanks a bunch. I'll get on it.
Old 13th June 2012
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
Here's a DIY on replacing just the reed switch. http://www.saabcentral.com/forums/sh...d.php?t=184277
Old 13th June 2012
Garage
Great, Jake, thanks!
Tags
coolant, level, low, sensor, tank
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Coolant expansion tank hose issue (Radiator coolant) KiriakosM C900 Workshop 10 10th June 2012 09:42 AM
car seams to run better on full tank 2000saab95 9-5 Workshop 5 25th February 2011 08:31 PM
Coolant full but still get SID Warning AERO BILL 9-5 Workshop 4 1st August 2010 12:13 PM
Wow...wow...wow. First full tank. s&d93 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 20 18th April 2009 02:57 AM
Gas smell with full tank.. strlinmoss C900 Workshop 0 25th October 2007 07:21 PM
