Click noise upon initial braking and acceleration - SaabCentral Forums
Old 08-06-12
a837584 a837584 is offline
My Saabs: 07 saab 9-3 arc
Default Click noise upon initial braking and acceleration
I been having this issue for over 2 months now. Its one click noise upon initial braking or acceleration. It doesn't have to be hard braking or acceleration. happens in straight lines as well as corners. Sound like its coming from the Front not sure what side. Also over bumps there is a clunking noise.
I have replaced the following so far.
Front brakes
Rotors
strut mounts w/ bearings
struts
tie rods
sway bar linkages
control arms and bushing
Front alignment
Re torqued the subframe
New tires
Any Ideas will be greatly appreciated.
Thank you in advance
2007 Saab 9-3 arc 110,000 miles
Old 09-06-12
derekwilkinson derekwilkinson is offline
My Saabs: 2006 Saab 9-3 2.0T JZW Stg 3
Did you do all that for the sound? You need to just have someone outside listen to where it is coming from, or even have it on a lift
BSR Intake, JZW Stage 3 Tune, Magnaflow Muffler, Tinted Windows, GS Strut Brace/Bushings/Downpipe, Koni Yellow Struts, Vogtland Lowering Springs, 25mm H&R Rear Spacers, Custom Leather Dash, Galaxy Tab 7, Hardwired V1, Boston Acoustics SE35, Sony Xplod 6x9s, Infinity Reference 6.5", Dual Kicker Comp 12"/Planet Audio 2500W Amp = Awesome
Old 09-06-12
Default Did you do all that for the sound?
No all that was not for the sound thats just the recent repair I have done, so you guys have all the information.
Two things Im thinking
cv joints and axels
or
sway bar bushing
Any thoughts in thinking that might be the problem
Old 11-06-12
aerodynamix aerodynamix is offline
My Saabs: 2007 9-3 aero 2.8t
i get that noise but i think its the rear brakes or rotors, i got them from brakeperformance.com and i didnt get the noise till a year or so after i installed them. i had the dimple rotors so i will get the oem saab rotors and pads, hopefully that will fix it. gl
Old 12-06-12
Wynnston Wynnston is offline
My Saabs: Saab 93
Sounds like cracked spring(s) or CV axel(s).
Old 12-06-12
Default Fixed!!
Turns out that the cheap sway bar linkages I got the driver side one was bad. The lower ball joint was loose and every time i accelerated and brake the body would roll and since the last past its gotten from a clicking noise to a clunking noise. Incase someone has the same problem and progressed passed the clicking.
Thanks for the replies guys much appreciated
Old 16-06-12
any pictures of the location? ty
Old 25-06-12
any update?
Tags
acceleration, braking, clicking, noise
Similar Threads
Loud click while braking fiveiron9688 Saab 9-3 & NG900 Workshop 3 19-10-09 10:23 PM
Moan under initial acceleration whiteblur Saab 9-5 Workshop 10 18-08-09 01:13 PM
87 8v 900 sputtering initial acceleration Focal Classic Saab 900 Workshop 13 14-08-09 06:27 AM
Clunk in left front on acceleration and braking soheeso Saab 9-3 & NG900 Workshop 6 25-03-08 07:40 PM
Click..click..click! noise from compressor and no cold air pinnacare-uk Saab 9-5 Workshop 1 04-06-07 09:14 AM
