less than 7psi? - SaabCentral Forums
Old 08-06-12
losacker losacker is offline
My Saabs: 1999 Saab 9-3 2 door (Full pressure)
Default less than 7psi?
ok so im having an issue. i have a MBC+A and i have been running it on 15 psi for a long while now and all of a sudden it wont boost more than 7 psi. i have tried turning the MBC up and nothing happens. i have the stock base intercooler and piping. i was thinking that since its the original piping i might have a boost leak from the rubber pipe since it is old and has some cracking. my thought was also on the waste gate. is there a way to rule out certain things to know for sure? any help is greatly appreciated. thanks!
Old 09-06-12
grkguy89's Avatar
grkguy89 grkguy89 is offline
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Garage
check your diverter valve ("blow off" valve)
it's probly the culprit
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 09-06-12
i hate to ask but how do i go about checking that lol. pull the vacuum hose off and plug said hose up and see if it boost fine? or should i take it off and is there a way to clean it? this could be a long lasting problem and it finally fully gave out. i wasnt seeing full boost(15psi) till about 3k. i have a cat delete and my MBC running 93 of course. stock tune and everything else is stock. THanks for the help! this is why i love this forum, you get a straight answer and people arent trying to troll (too much at least lol)
Old 09-06-12
patterson2537's Avatar
patterson2537 patterson2537 is online now
My Saabs: ng 900 se convertible
can you hear a whistling or a honking then it is the diverter. if so and you have the original Bosch then you need a new one
Old 09-06-12
right on the money sir. i have recently heard a loud honking when i wouldnt fully let out of the throttle and i thought it was just the perfect pressure and opening to make that sound. i believe it is the original bosch diverter valve so that would be the issue i believe. thanks for your input. it is all greatly appreciated. once i put a new one on i will make sure that is the case and get back to you guys. thanks again
Old 09-06-12
happy to be of help
Old 26-06-12
so i installed a new diverter valve and i am still getting the same problem and this valve, it is brand new, is also honking, what are the chances of having two bad valves in a row?
Old 26-06-12
grkguy89's Avatar
Moderator
Garage
it is def possible that it is bad if it's honking
Old 26-06-12
damn. im really starting to get frustrated, i have a greddy type rs bov but the piece i recived with it is about 2" instead of 1", is there a reducer or could i find a 1" with that flange at the auto parts store?
Old 26-06-12
grkguy89's Avatar
Moderator
Garage
you might be able to get a rubber hose with the reduction you need
Old 26-06-12
would that be at an autoparts store or a hardware store?
Old 26-06-12
grkguy89's Avatar
Moderator
Garage
either or... probly a better chance at an auto parts store
Old 26-06-12
Pontius DIO's Avatar
Pontius DIO Pontius DIO is offline
My Saabs: 99' 9-3 SE GT2560 62 Trim Comp.
You could always have a shop weld a 2" ring onto the pipe to accept the new BOV.
Similar Threads
5-7psi no matter what i do!! Sluice Box Hero Saab 9-3 & NG900 Performance, Mods & Tuning 17 13-04-10 02:11 PM
Only 6-7psi of boost on my 1995 AERO MURZYN Saab 9000 Workshop 5 18-07-05 09:59 PM
